Noahkk19 Posted May 17, 2006 Author Report Share Posted May 17, 2006 Will try Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 17, 2006 Author Report Share Posted May 17, 2006 New Development:So I pull the plugs, I only check 3 and it looks like it hasn't even fired...So to compare to another I pull out spark plug 1 and it sure enough looks like it's fired...Spark plug 3 isn't even firing it looks like...Let's see if this picture can show you guys...Blurry but does the job...left one is cylinder 1 right one is cylinder 3 Link to comment Share on other sites More sharing options...
ziddey Posted May 17, 2006 Report Share Posted May 17, 2006 you sure the cap and rotor are good?? wires in snug? Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 17, 2006 Author Report Share Posted May 17, 2006 Perfect...And what are the chances on this EARTH of only cylinder 3 not firing with a distributor rotor and wires off of a different car? And honestly the new ones I have on now are in perfect shape, the pictures tell all, brand new I'm confused :monkey: Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 17, 2006 Author Report Share Posted May 17, 2006 you sure the cap and rotor are good?? wires in snug?ok QUESTION...If I had absolutely no compression in cylinder 3...Would that cause there to be no spark? Or would I get a spark compression or no compression? Link to comment Share on other sites More sharing options...
ziddey Posted May 17, 2006 Report Share Posted May 17, 2006 what controls the signal to the ignition coil?does the volvo have a pickup coil or something of the like? maybe some other type of sensor?? camshaft position sensor?? Can you yank the entire dizzy from the other volvo and put it on?ok QUESTION...If I had absolutely no compression in cylinder 3...Would that cause there to be no spark? Or would I get a spark compression or no compression?You could try putting down a teaspoon ofmotor oil in the cylinder and see what happens Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 18, 2006 Author Report Share Posted May 18, 2006 what controls the signal to the ignition coil?does the volvo have a pickup coil or something of the like? maybe some other type of sensor?? camshaft position sensor?? Can you yank the entire dizzy from the other volvo and put it on?You could try putting down a teaspoon ofmotor oil in the cylinder and see what happensI can deffinitely use every ignition component from the other Volvo...I'm just confused as to what the codes are giving, if there were more it'd probably help...Maybe ignition coil is to blame? I took it off already, inspected it, cleaned it for the hell of it...BHAAHDSDAHADSHSDKlhaha, what will dropping a teaspoon of motor oil do? Link to comment Share on other sites More sharing options...
ziddey Posted May 18, 2006 Report Share Posted May 18, 2006 I can deffinitely use every ignition component from the other Volvo...I'm just confused as to what the codes are giving, if there were more it'd probably help...Maybe ignition coil is to blame? I took it off already, inspected it, cleaned it for the hell of it...BHAAHDSDAHADSHSDKlhaha, what will dropping a teaspoon of motor oil do?I think the coil is fine since it by itself can't distinguish between the cylinders so it's whatevers telling it when to fire. Hence the distributor since it has two jobs.The teaspoon of oil will restore compression if it's out due to flooding or whatnot (Is that even a word? Let me check the dictionary. No it's a not a word, I'm dumb!) Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 18, 2006 Author Report Share Posted May 18, 2006 Just did a check and it showed that the wire for cylinder 3 is firing Link to comment Share on other sites More sharing options...
ziddey Posted May 18, 2006 Report Share Posted May 18, 2006 Just did a check and it showed that the wire for cylinder 3 is firingstuff I'm sorry I forgot to mention to check that first. Basics first, right? Good job for doing that!!So that means the spark plug is going off. Cylinder was probably flooded. Drop some oil in it and give it a go and go for a spin. Probably needs to be cleared out Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 18, 2006 Author Report Share Posted May 18, 2006 Will give it a go Link to comment Share on other sites More sharing options...
mike850r Posted May 18, 2006 Report Share Posted May 18, 2006 do you have a ohm meter?...check for cont. on all the wires and resistance...i forget how many ohms they are supposed to be, broken plug wire?, and maybe some old school marvel mystery oil in that cylinder? Link to comment Share on other sites More sharing options...
Chris_R Posted May 18, 2006 Report Share Posted May 18, 2006 Shouldn't that #3 plug be soaked with fuel if it's not firing? If it was firing without fuel I think it would look just like that one.You said you switched injectors, right? Link to comment Share on other sites More sharing options...
Noahkk19 Posted May 18, 2006 Author Report Share Posted May 18, 2006 Yeah I did...Took it to the shop, they ran a compression test and the result is...NO COMPRESSION in cylinder 3... I just got drilled <_< Link to comment Share on other sites More sharing options...
ziddey Posted May 18, 2006 Report Share Posted May 18, 2006 Yeah I did...Took it to the shop, they ran a compression test and the result is...NO COMPRESSION in cylinder 3... I just got drilled hmm, did you ever try the oil in the cylinder? sorry to hear that Link to comment Share on other sites More sharing options...
