trance42 Posted May 17, 2006 Report Share Posted May 17, 2006 I cant figure out whats going on. When i drive normally i have no problem. As soon as i go over 5-10 bs of boost i get this studder. The boost stays where it is. I have 750 cc injectors and garett turbo. I am not tuned yet but i hav not had this problem yet. i have been driving The car since christmas. I pulled codes. some i can find info for others i have no clue what they are. 335543455454542231453452214I know what 335 231 and 214 are. the 231 is because im running rich. 335 manual swap. 214 possible bad rpm sensorDoes anyone know what theese other codes are?I would apriciate any thoughts that anyone might have on this.Tim Link to comment Share on other sites More sharing options...
jediboytj Posted May 17, 2006 Report Share Posted May 17, 2006 higher octane fuel maybe? that fixed my stutter/hesitation on full boost in higher RPMs. :unsure: Link to comment Share on other sites More sharing options...
grocerygetter Posted May 17, 2006 Report Share Posted May 17, 2006 Have you changed plugs recently? Try that, if you are running rich they tend to foul quicker. Link to comment Share on other sites More sharing options...
trance42 Posted May 17, 2006 Author Report Share Posted May 17, 2006 what plugs should i get for my set up. Link to comment Share on other sites More sharing options...
maiku Posted May 17, 2006 Report Share Posted May 17, 2006 search spark plugs Link to comment Share on other sites More sharing options...
trance42 Posted May 17, 2006 Author Report Share Posted May 17, 2006 spark plug is talked about in like 943832098432098432098 posts. some times its a pita to search because you have sort through all 439809809328 usless times sparkplug was typed. Ill try all 53 pages of hits anyway.. Link to comment Share on other sites More sharing options...
prasamin Posted May 17, 2006 Report Share Posted May 17, 2006 just get some coppers and gap them down to .022-.023 and call it a day.I'm using Champion RC7YC plugs, as are some others, but just get some 7 temp range coppers and gap them, that's what it's all about. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted May 17, 2006 Report Share Posted May 17, 2006 P0335 - Crankshaft Position Sensor A Circuit MalfunctionP0455 - Evaporative Emission Control System Tank Detected (gross leak)P0454 - Evaporative Emission Control System Pressure Sensor IntermittentP0231 - Fuel Pump Secondary Circuit LowP0453 - Evaporative Emission Control System Pressure Sensor High InputP0452 - Evaporative Emission Control System Pressure Sensor Low InputP0214 - Cold Start Injector 2 Malfunction542 and 543 come up as unknown codes-Rob Link to comment Share on other sites More sharing options...
javadoc Posted May 17, 2006 Report Share Posted May 17, 2006 You have 750cc injectors, a bigarse Garrett, no tuning and....? Link to comment Share on other sites More sharing options...
Sean Posted May 17, 2006 Report Share Posted May 17, 2006 Does doubling your injectors size like that kill your gas milage? Link to comment Share on other sites More sharing options...
trance42 Posted May 17, 2006 Author Report Share Posted May 17, 2006 Thanks for the good info Rob.The emissions is because of having a 97 motor in a 95 car.It doesnt really worry me.On the other hand these worry me. -Crankshaft Position Sensor A Circuit Malfunction -Fuel Pump Secondary Circuit Low -Cold Start Injector 2 MalfunctionAny one else had these probems before? No the injectors do not cause bad gas milage? they are saturated injectors so as long as im not flooring it im geting around 18-20 in the city. i did over 400 miles on one tank of gas on the interstate. Link to comment Share on other sites More sharing options...
BlackT5 Posted May 17, 2006 Report Share Posted May 17, 2006 get the car tuned!are you running a stock or modified ECU? Link to comment Share on other sites More sharing options...
the underlørd Posted May 17, 2006 Report Share Posted May 17, 2006 get the car tuned!are you running a stock or modified ECU?the million $ q. Link to comment Share on other sites More sharing options...
trance42 Posted May 17, 2006 Author Report Share Posted May 17, 2006 bsr stage three ecu.i went out and took the wire harness off injector 2 and put it back on.. no more studder. i guess it was a bad conection. problem solved for the moment. now to figure out whats causing the other codes. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted May 18, 2006 Report Share Posted May 18, 2006 bsr stage three ecu.i went out and took the wire harness off injector 2 and put it back on.. no more studder. i guess it was a bad conection. problem solved for the moment. now to figure out whats causing the other codes.1 down, and a thousand to go j/k -Rob Link to comment Share on other sites More sharing options...
