8G5L0T Posted May 21, 2006 Report Share Posted May 21, 2006 Im going to block out my grill today. Should I stay away from spray paint ? If so, i can pick up any black paint from my local hardware store and be set right? Did any of you guys use a primer on your grill? Link to comment Share on other sites More sharing options...
JMK33 Posted May 21, 2006 Report Share Posted May 21, 2006 Plastidip You might want to lightly sand it so the paint holds on better. I'd stay away from spray paint though , because it has a better chance of chipping. Link to comment Share on other sites More sharing options...
Mattphi Posted May 21, 2006 Report Share Posted May 21, 2006 yup Link to comment Share on other sites More sharing options...
Jaxx Posted May 21, 2006 Report Share Posted May 21, 2006 Spray is good, as long as you follow directions.Depending on the finish you want, if you want to make it look like theres nothign there, get flat black. if you want it be shiny, get satin, gloss or high gloss, maybe even clear coat.you can pick up any black spray paint, but make sure its just not indoor only. any outdoor paint will work well, I've heard Krylon Fusion is good.make sure you sand lightly, shake the cans well, make sure its above 60 degrees or so, if you want, you can put the cans in warm water to let the paint stick better and be less runny.when painting, be sure to do lots of light coats, waiting at least 15 minutes inbetween. This will help runs, chipping, and finish.things to remember: prep is 80% of the job, prep well, most likely you'll have a good paint job that you'll be proud of. mask off what you want, be sure to do it in a well lit area, and well ventilated, dust masks don't block fumes. have anymore questions? ask! it'll turn out better! good luck,-jaxx Link to comment Share on other sites More sharing options...
Mattphi Posted May 21, 2006 Report Share Posted May 21, 2006 oh yea, take some pics too Link to comment Share on other sites More sharing options...
8G5L0T Posted May 21, 2006 Author Report Share Posted May 21, 2006 oo don't you guys worry it will be pictures gallore Link to comment Share on other sites More sharing options...
merlin390 Posted May 21, 2006 Report Share Posted May 21, 2006 degrease, sand, degrease again. dry, adhesion promotor, lots of light coats of paint, and clear. Link to comment Share on other sites More sharing options...
8G5L0T Posted May 21, 2006 Author Report Share Posted May 21, 2006 Beforereppin that ishsandpapering finishedafteri say it turned out good, time to watch the pistons whoop some a Link to comment Share on other sites More sharing options...
Jaxx Posted May 21, 2006 Report Share Posted May 21, 2006 LOOKS GOOD!dam caps lock.get a tow hook cover! :P Link to comment Share on other sites More sharing options...
volvogeek Posted May 21, 2006 Report Share Posted May 21, 2006 I did the same thing to my 855R earlier this week...how did you get the clips off the slash? It looked to me like they'd snap the mounts off if I tried, so I just taped over it.Now I need to get some trim black and black that out too... Link to comment Share on other sites More sharing options...
Jaxx Posted May 21, 2006 Report Share Posted May 21, 2006 u gotta tap them with a sharp point, such as a screwdriver, and bend them. Link to comment Share on other sites More sharing options...
Mattphi Posted May 21, 2006 Report Share Posted May 21, 2006 How about i just realized that you are in Orlando...Darn. If i woulda realized that we coulda met up and done both your grille and my stock one too... Link to comment Share on other sites More sharing options...
Oreo931 Posted May 22, 2006 Report Share Posted May 22, 2006 looks awesome man! great work. Link to comment Share on other sites More sharing options...
HPTDoh Posted May 22, 2006 Report Share Posted May 22, 2006 Looks much better :) Link to comment Share on other sites More sharing options...
Ayte54R Posted May 23, 2006 Report Share Posted May 23, 2006 Looks good! What did you end up using? Spray paint? Link to comment Share on other sites More sharing options...
