CRK Posted May 25, 2006 Report Share Posted May 25, 2006 I have a cel code p0440, I know it is a evap code but what components need to be checked? Does anybody have the factory suggestions for that code? TIA.. Link to comment Share on other sites More sharing options...
the underlørd Posted May 25, 2006 Report Share Posted May 25, 2006 who's ready for a ride? WHEEEEEEEeee!one!one!off to maintenance. Link to comment Share on other sites More sharing options...
CRK Posted May 26, 2006 Author Report Share Posted May 26, 2006 oops my bad, thanks for the ride to the correct section. Link to comment Share on other sites More sharing options...
A pimp named Slickback Posted May 26, 2006 Report Share Posted May 26, 2006 That's the evap major leak code. Tighten your gas cap Link to comment Share on other sites More sharing options...
CRK Posted May 26, 2006 Author Report Share Posted May 26, 2006 That's the evap major leak code. Tighten your gas capThats already been done do you think a new cap is due? Are there other things to check? Link to comment Share on other sites More sharing options...
CRK Posted May 29, 2006 Author Report Share Posted May 29, 2006 BTT :) Link to comment Share on other sites More sharing options...
CRK Posted August 14, 2006 Author Report Share Posted August 14, 2006 So I have replaced the gas cap cleared the codes and noe the CL is on with same code. Can some one tell me the next thing I should replace/repair/check ??? :( Link to comment Share on other sites More sharing options...
MadeInJapan Posted August 14, 2006 Report Share Posted August 14, 2006 Next check all of your vacuum hoses including your little elbows...the ones at the front left and right edge of the intake manifold. Link to comment Share on other sites More sharing options...
CRK Posted October 8, 2006 Author Report Share Posted October 8, 2006 More info still have the same code. Gas cap is new evap valve replaced New intercooler hoses New vac hoses Elbows on the manifold look and feel good Vaccum is ~ 21inch Boost is ~ 16 psi if I roll into it. If I floor the pedal it goes to 10 psi then climbs up to 16. It will hold 16psi to red line.--------------------------------------------------------------------------------------- When messing around with the evap valve I did get code P0444 which said exactly that >>>evap valve misfunction. The car has been running rich this whole time and MPG is around 19-19.5 With out taking stabs in the dark does anybody have an idea on to check next? Link to comment Share on other sites More sharing options...
garbergtsi Posted October 8, 2006 Report Share Posted October 8, 2006 make sure that the vent valve closes when 12v is applied to it.thats about the only thing left in the system Link to comment Share on other sites More sharing options...
smokin' T5M Posted October 9, 2006 Report Share Posted October 9, 2006 Do you have the ability to pressurize the evap syst with a gauge? If you can clamp off the shut of valve hose that goes to atmosphere. Put a mild amount of air in the system towards the tank (Don't blow up the tank!) After you pressurize the tank see if you loose pressure. If you loose pressure there is a line that is leaking. Did it need the recall for the dampers on the tank? The fuel pump could be leaking through where the harness comes through at the top of the tank. There are hoses on top of the tank that can leak too. Have fun Sherlock :) Link to comment Share on other sites More sharing options...
