echristodo Posted June 2, 2006 Report Share Posted June 2, 2006 I have access to a set of used injectors mounted (stuck) on a fuel rail from a '96 turbo that I would like to throw on my '98 T5 to see if they quell a problem. Will this swap work? Is there any difference between the two? The regulator is already on it as well... Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted June 2, 2006 Report Share Posted June 2, 2006 I have access to a set of used injectors mounted (stuck) on a fuel rail from a '96 turbo that I would like to throw on my '98 T5 to see if they quell a problem. Will this swap work? Is there any difference between the two? The regulator is already on it as well...Who the heck knows? Link to comment Share on other sites More sharing options...
Zappo Posted June 2, 2006 Report Share Posted June 2, 2006 They will fit in just like your stock ones. However, they are a lower rating than your stock whites. The 850 injectors should be an orange color. They will probably work fine driving around town, but you wouldn't want to go WOT with them. Link to comment Share on other sites More sharing options...
