echristodo Posted June 3, 2006 Report Share Posted June 3, 2006 My friend has a 1998 S70 T5 with about 120k, 70k on a new engine, and his car wont start. It struggles when turning over and sometimes will start, barley idle at 900, and then die again. MAF sensor...? Link to comment Share on other sites More sharing options...
connorb850 Posted June 3, 2006 Report Share Posted June 3, 2006 MAF is possible, see if unplugging it makes the car run any better. Also, any codes? Link to comment Share on other sites More sharing options...
RussB Posted June 3, 2006 Report Share Posted June 3, 2006 ...It struggles when turning over and sometimes will start...Test the battery and charging system Link to comment Share on other sites More sharing options...
echristodo Posted June 3, 2006 Author Report Share Posted June 3, 2006 MAF is possible, see if unplugging it makes the car run any better. Also, any codes?Can't get it on long enough to see if there is a check engine light, but were gonna get a friend to bring his OBDIII unit down tonight... Link to comment Share on other sites More sharing options...
ziddey Posted June 3, 2006 Report Share Posted June 3, 2006 wow what happened? 120k with a 70k engine?? what caused that?? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted June 3, 2006 Report Share Posted June 3, 2006 I know the guy, I bet it was lack of oil changes Never did get the entire story on that. Anyways, tell Toby to unplug the MAF like the other guy said, you know where it is? Don't forget to put the zip tie back on, 98 only recall. Link to comment Share on other sites More sharing options...
echristodo Posted June 3, 2006 Author Report Share Posted June 3, 2006 I know the guy, I bet it was lack of oil changes Never did get the entire story on that. Anyways, tell Toby to unplug the MAF like the other guy said, you know where it is? Don't forget to put the zip tie back on, 98 only recall.Lol, you were the "friend" and Tobe pussed out so his volvo will have to wait till saturday... hope he can get away with cleaning the MAF... don't know how much the pyramid scheme pays, but that sensor is what, $150? Link to comment Share on other sites More sharing options...
echristodo Posted June 5, 2006 Author Report Share Posted June 5, 2006 So I went over to the buddies house this afternoon to try and defibulate his car and the thing started up with protest and then eventually was running relatively smoothly... on its own! Condensation in the distributor? Gnomes crawling through the intake? Link to comment Share on other sites More sharing options...
Mr. Norm Posted June 5, 2006 Report Share Posted June 5, 2006 So I went over to the buddies house this afternoon to try and defibulate his car and the thing started up with protest and then eventually was running relatively smoothly... on its own! Condensation in the distributor? Gnomes crawling through the intake?I had a similar problem, turned out to be the temp sensor by the thermostat. Mine would start only if I had my foot on the brake pedal, it would catch and idle real rough for 2-4 minutes, then run ok again. Link to comment Share on other sites More sharing options...
echristodo Posted June 5, 2006 Author Report Share Posted June 5, 2006 I had a similar problem, turned out to be the temp sensor by the thermostat. Mine would start only if I had my foot on the brake pedal, it would catch and idle real rough for 2-4 minutes, then run ok again.How can we determine with certainty that this is the problem, short of replacing the tempo? Clean the old one... would unplugging it take care of it? Link to comment Share on other sites More sharing options...
Mr. Norm Posted June 5, 2006 Report Share Posted June 5, 2006 My IM is able to monitor the performance of the temp sensor, dunno how. If you are in Chicago I could send you to him. Link to comment Share on other sites More sharing options...
