Matts 850 GLT Posted June 8, 2006 Report Share Posted June 8, 2006 HelloHave been looking at various cars for sale. Found a nice 95 855n/a. Anyway it comes fully dealer serviced at 78,000 miles. One owner. I checked the dealer who had serviced it to verify its history and yes they have kept it serviced. Great.Question. At 60,000 mile service I thought they would change the coolant (every 30,000miles or 2years)? They don't. The aftersales manager said 'they only do whats necessary'. There is a note by the service manager on the service sheet 'recommend changing coolant'!!!!So, go figure, what else needs doing????Anyway the car is great but I will get my own indy to service it, at least then I know it is correctly looked after.Matt Link to comment Share on other sites More sharing options...
maiku Posted June 8, 2006 Report Share Posted June 8, 2006 no turbo? Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted June 8, 2006 Author Report Share Posted June 8, 2006 no turbo?No! and it shows... most turbo wagons are well over 150,000 miles with dubious service history. I need something for my wife to drive with the kids in. I might look for a subaru evo6. Matt Link to comment Share on other sites More sharing options...
Mr. Norm Posted June 8, 2006 Report Share Posted June 8, 2006 Flush the tranny fluid. The dealer will tell you it never needs to be done, they also get to sell new trannies to folks. Link to comment Share on other sites More sharing options...
James100 Posted June 8, 2006 Report Share Posted June 8, 2006 HelloHave been looking at various cars for sale. Found a nice 95 855n/a. Anyway it comes fully dealer serviced at 78,000 miles. One owner. I checked the dealer who had serviced it to verify its history and yes they have kept it serviced. Great.Question. At 60,000 mile service I thought they would change the coolant (every 30,000miles or 2years)? They don't. The aftersales manager said 'they only do whats necessary'. There is a note by the service manager on the service sheet 'recommend changing coolant'!!!!So, go figure, what else needs doing????Anyway the car is great but I will get my own indy to service it, at least then I know it is correctly looked after.MattMaybe thats why my car that was dealer serviced by the pevious owner had a Nissens radiator in it . I got it at 7 years old so the first radiator lasted less than 7 years. Maybe they never changed the coolant. Link to comment Share on other sites More sharing options...
BananeR Posted June 8, 2006 Report Share Posted June 8, 2006 Flush the tranny fluid. The dealer will tell you it never needs to be done, they also get to sell new trannies to folks.what's a good interval for tranny fluid changes on 850T's? Link to comment Share on other sites More sharing options...
the underlørd Posted June 8, 2006 Report Share Posted June 8, 2006 what's a good interval for tranny fluid changes on 850T's?when it smells burned or, loses that pinkish red color. Link to comment Share on other sites More sharing options...
James100 Posted June 8, 2006 Report Share Posted June 8, 2006 what's a good interval for tranny fluid changes on 850T's?There used to be a write up and pics in Repairs/Maintenance also check there. Link to comment Share on other sites More sharing options...
rodrigo Posted June 8, 2006 Report Share Posted June 8, 2006 I just had a good one about10 min ago...the cars at the dealer for a 60,000 mile service.60K service: $698.00then they suggested I need a coolant replacement and thermostat replacement: $220.00then they suggested I so a trans fluid replacement: $125.00those freekin stamps in the maintenance book are getting expensive... ...and they mentioned nothing of the cracked serpentine belt they noticed when I went in for an ETM upgrade...and I have not changed it...I guess it fixed itself? take it to an independant mechanic that is familiar with Volvo's and their maintenance schedules and flip off the dealer everytime you drive by...with a smile of course. yes, im bitter when it smells burned or, loses that pinkish red color.i dont thinkit should go more than 30k without a change regardless??? :unsure: Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted June 8, 2006 Author Report Share Posted June 8, 2006 I know...So why get the car serviced when all they do is tell you what needed and charge you for it? What is the point of a service schedule when the dealers don't follow it?m Link to comment Share on other sites More sharing options...
robert213 Posted June 8, 2006 Report Share Posted June 8, 2006 Genuine Volvo Service - 850 series 1995-1997Every 10,000 miles:Oil Filter & Engine Oil: ReplaceBattery Test: Check Electrolyte Level and ClampsBrake Pads: Check Wear-- In my experience, OEM Brake Pads must be replaced every 25K milesAutomatic Transmission: Check Shift Control; Check Fluid Level-- In my experience, ATF must be changed every two years-- Note 1998 Model Years and older use DEXRON-III-- Note 1999 Model Years and newer use Mobil/Volvo JWS 3309. ---- It is not synthetic. It is expensive at $18/quart.Fluid Levels: Check/Adjust (Coolant, brake fluid, power steering and washer)-- Note Our power steering system uses DEXRON-III, not generic PS fluidDiagnostic Codes: Check, ResetTires: Check for damage and wear (Rotate at customer's request)Lubricate: Hood Hinges, Door Hinges, Door Striker Plates, Clean: Power AntennaReset: Service LightEvery 20,000 miles:Brake Hoses: CheckFuel Lines: CheckSteering, Front & Rear Suspension: CheckDrive Shaft Joints: Check for wear/playLubricate Belt Tensioner Pivot Bearing-- I would guess this means both Serpentine and TimingEvery 30,000 miles: Air Filter Cartridge: ReplaceSpark Plugs: ReplaceBrake Fluid: Replace at interval or every two yearsEvery 60,000 miles:Drive (Serpentine) Belts: ReplacePCV: Replace Flame Guard, Clean Nipple and HosesEvery 70,000 miles:Timing Belt: ReplaceEvery 100,000 miles:EGR System: Check and CleanFuel Filter: Replace------------------------------------------------------------Here is a list of items that have been omitted...1) ATF: Replace2) Coolant: Replace3) Thermostat/Engine Coolant Temp (ECT): Replace4) Water Pump: Replace5) O2 Sensor: Replace6) Ignitor Module: Replace7) Struts/Spring Seats: ReplaceSee the remainder of the items in "Stage 0" FAQ post--------------------------------------------------------------- Link to comment Share on other sites More sharing options...
James100 Posted June 8, 2006 Report Share Posted June 8, 2006 Genuine Volvo Service - 850 series 1995-1997Every 10,000 miles:Oil Filter & Engine Oil: Replace3K for me on the oil change. 10K is like way to long IMO As I recall some of those guys that never changed their oil had the PCV blow up on them. :( Link to comment Share on other sites More sharing options...
maiku Posted June 8, 2006 Report Share Posted June 8, 2006 lol at 10000k milesi'm sure something is wrong therei usually change around 3k Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted June 8, 2006 Author Report Share Posted June 8, 2006 Here is a list of items that have been omitted...1) ATF: Replace2) Coolant: Replace3) Thermostat/Engine Coolant Temp (ECT): Replace4) Water Pump: Replace5) O2 Sensor: Replace6) Ignitor Module: Replace7) Struts/Spring Seats: ReplaceSee the remainder of the items in "Stage 0" FAQ post--------------------------------------------------------------- Link to comment Share on other sites More sharing options...
rodrigo Posted June 8, 2006 Report Share Posted June 8, 2006 My ignition leads have a date '1995' printed on them. Original, even after 11 years they still work i think the OEM ignition components have been seen to surpass 100k with no problems at all...that is distributor, rotor, leads...not that I would do that.Genuine Volvo Service - 850 series 1995-1997Every 10,000 miles:Oil Filter & Engine Oil: Replacethats nuts. i guess it depends ont he oil and the type of driving, or someone who smaples oil...etc. i check my oil every week, change it every 3k. Link to comment Share on other sites More sharing options...
