15g Swap Into A S70glt
Huuuuuge bump but didn't want to start another thread...so quick question, plus this thread might help other LPT people
the turbo flange for a 15G is a v-band correct? not T3 or T4...
Yes it is.
  • Replies 42
cool thank you for the quick confirm. i'm getting an estimate from a local shop for a 3" turboback set up and completely blanked on the flange type...should probably go to bed
wtf? v band?
if you are reffering to the turbos exhaust inlet, that's basically a t3 bolt pattern.
a conical exhaust outlet flange is NOT a v band. none of them are.
wtf? v band?
Hmm i thought he was talking about the connection between the compressor side and the exhasut side
Ok i am confused now, I am getting an estimate for a turboback exhaust, so I want the connection between the turbo and downpipe...does the Vband connect the exhaust housing to the exhaust or what?
No it doesnt. Its connected by bolts. There is a kinda V-band between the compressor side and the exhaust side of the turbo.
wtf? v band?
it's going to be an angled outlet, i don't know if that makes a difference or not. I wish i could get two people to say the same thing in this thread haha.
I have the exact car you have, I have done a turbo swap not more than a month ago and I can walk outside and take pictures if you would like. Here ill post you a picture of the 13g ANGLED exhaust side with custom 3inch DP:
This is what a conical outlet look like.
If you are just swapping the compressor side then have them make the DP up to fit your stock 13G angled flange. Otherwise you will have to swap the turbo before they can make you up the DP.
Alright sounds good, I had sent the people giving me an estimate an email saying it was a V band connection so I just wanted to figure it all out and send a correction email before they did my estimate. I will definitely get the 15G in before they do the exhaust and DP.
