Marciano Posted June 17, 2006 Report Share Posted June 17, 2006 First thanks to eveyone for all your advice and help on my first T-belt change. I have never even owned a Volvo and this one I bought about 3 weeks ago. The next fix I need to go after on my V70 is the rear latch and the passenger side CV boot is partially torn loose. Anyone have experience with either one these? Link to comment Share on other sites More sharing options...
Seamus Posted June 17, 2006 Report Share Posted June 17, 2006 Rear latch?? Link to comment Share on other sites More sharing options...
Marciano Posted June 17, 2006 Author Report Share Posted June 17, 2006 Rear latch??On my V70 the big back rear door that opens straight up will not latch. It seems as though the latch mechanism od the door itself is not working properly. It feels like the spring is not working right within the latch. Link to comment Share on other sites More sharing options...
AGBullit235 Posted June 17, 2006 Report Share Posted June 17, 2006 Yeah that happens (the latch). Apparently they changed the latch design on the V70's to make it a bit cheaper than the 850 ones. Mine broke, and I replaced it with an 850 latch (which is a tank). However I can't use the rear key hole, but it works fine otherwise (not that I care about using the key on the trunk).The V70 latch mech is allot cheaper to replace than the 850 one. The install is very easy. Link to comment Share on other sites More sharing options...
Marciano Posted June 17, 2006 Author Report Share Posted June 17, 2006 Yeah that happens (the latch). Apparently they changed the latch design on the V70's to make it a bit cheaper than the 850 ones. Mine broke, and I replaced it with an 850 latch (which is a tank). However I can't use the rear key hole, but it works fine otherwise (not that I care about using the key on the trunk).The V70 latch mech is allot cheaper to replace than the 850 one. The install is very easy.I have only been able to find one at the dealer, can you not get them from Volvo parts stores? I assume you have to take interoir panel off? Link to comment Share on other sites More sharing options...
prasamin Posted June 17, 2006 Report Share Posted June 17, 2006 my 850 latch never latches all the way...i have to constantly slam the tailgate to get it to catch....still havent figured out how to fix this. Link to comment Share on other sites More sharing options...
Kashif Posted June 17, 2006 Report Share Posted June 17, 2006 First thanks to eveyone for all your advice and help on my first T-belt change. I have never even owned a Volvo and this one I bought about 3 weeks ago. ....the passenger side CV boot is partially torn loose. Anyone have experience with either one these?Yeah I too have a torn CV boot that I am about to repair. When I do I'll post a write, hopefully. Link to comment Share on other sites More sharing options...
James100 Posted June 17, 2006 Report Share Posted June 17, 2006 CV boot is partially torn loose. Anyone have experience with either one these?CV boot-You can get it fixed for $60(1) for everything if you shop around. Maybe cheaper where you live.You might want to read this before you do it. CV Boot Link to comment Share on other sites More sharing options...
Marciano Posted June 18, 2006 Author Report Share Posted June 18, 2006 Yeah I too have a torn CV boot that I am about to repair. When I do I'll post a write, hopefully.I think I am going to go ahead and do the axle. Is there step by step instructions on Bay 13? Link to comment Share on other sites More sharing options...
James100 Posted June 18, 2006 Report Share Posted June 18, 2006 I think I am going to go ahead and do the axle. Is there step by step instructions on Bay 13?Don't think so. I dont see it. But there is alot on that on this site if you do a search. Maybe you will make one(step by step instructions). You take good pics. I saw your timing belt ones. :tup: Link to comment Share on other sites More sharing options...
