Swedish Mike Posted June 25, 2006 Report Share Posted June 25, 2006 As I saw the cylinders were OK.But if you hone the cylinders it will last for many km?I love my car but I am really dissapointed from it concerning the oil consumption.I was thinking to do other modifications when I took it(S60R rims,change the leather seats with new,turbo etc.....)but now I have to open the engine's internals again.and the other strange is that it has very,very good performance.Maybe you use a 0w40 oil? To hot for that now./Mike Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted June 25, 2006 Report Share Posted June 25, 2006 Maybe you use a 0w40 oil? To hot for that now./MikeI've run about 70000km since I changed the rings,to tell you the truth I changed everything,except the pistons which were in good condition,I used shell 15w-50,no difference,then I used shell 5w-40 the same,then motul 300v 15w-50 the same again and now I use from Volvo 10w-40 semi-synthetic and the same result again!I believe that I sould throw the engine.But I threw my money to refresh it. Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 25, 2006 Report Share Posted June 25, 2006 I've run about 70000km since I changed the rings,to tell you the truth I changed everything,except the pistons which were in good condition,I used shell 15w-50,no difference,then I used shell 5w-40 the same,then motul 300v 15w-50 the same again and now I use from Volvo 10w-40 semi-synthetic and the same result again!I believe that I sould throw the engine.But I threw my money to refresh it.Probably worn out cylinders, need new bore and OD pistons./Mike Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted June 25, 2006 Report Share Posted June 25, 2006 Probably worn out cylinders, need new bore and OD pistons./MikeThanks for your replys Mike I found a person in sweden,who sells pistons and rods,I think that I'll buy from him the parts,his price was very attractive.less than 2000 euros for pistons and h rods. Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 25, 2006 Report Share Posted June 25, 2006 Thanks for your replys Mike I found a person in sweden,who sells pistons and rods,I think that I'll buy from him the parts,his price was very attractive.less than 2000 euros for pistons and h rods.Just PM me before you buy parts. I can get better parts than SPM for the same price./Mike Link to comment Share on other sites More sharing options...
PenguinScotty Posted June 25, 2006 Author Report Share Posted June 25, 2006 The 500 bucks one runs/was running before it got removed from the car.I was planning on using Venolia Pistons and SPM Rods. If the crank is alright, i would definitely keep it in there, mainly because i'm not planning on going past 450 hp for a while. If the head is alright, i might just clean it up and slap it back on there, however, if there is a problem with the seal or valves, i might just go all out, get it milled, bored and replace valves and springs and other misc parts. Also, depending on the condition of the block i might get it honed. Thanks for the input guys, appreciate it alot. Seems like i'm going to go with the 500 dollar one and just turn it into a like-new condition :P Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 26, 2006 Report Share Posted June 26, 2006 The 500 bucks one runs/was running before it got removed from the car.I was planning on using Venolia Pistons and SPM Rods. If the crank is alright, i would definitely keep it in there, mainly because i'm not planning on going past 450 hp for a while. If the head is alright, i might just clean it up and slap it back on there, however, if there is a problem with the seal or valves, i might just go all out, get it milled, bored and replace valves and springs and other misc parts. Also, depending on the condition of the block i might get it honed. Thanks for the input guys, appreciate it alot. Seems like i'm going to go with the 500 dollar one and just turn it into a like-new condition You should definatly bore that block to OD, they are not straight in the cylinders after that milage.Looks like waves in the cylinder walls if you measure it./Mike Link to comment Share on other sites More sharing options...
PenguinScotty Posted June 26, 2006 Author Report Share Posted June 26, 2006 Roger that. Going to go all out on the block then. Better safe than sorry. Just curious because i'm not 100% sure, but the stock crank should (theoretically) be able to hold 450hp right? Thanks again Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 26, 2006 Report Share Posted June 26, 2006 Roger that. Going to go all out on the block then. Better safe than sorry. Just curious because i'm not 100% sure, but the stock crank should (theoretically) be able to hold 450hp right? Thanks againWithout any problems but the lighter RN crank is better for high rpm´s. You can find it in the newer T5´s.I would probably use the 850 one to keep the cost down./Mike Link to comment Share on other sites More sharing options...
