VolvoFan Posted July 2, 2006 Report Share Posted July 2, 2006 I finally got everything all doctored up and neatened under the hood. The pipercross filter got busted so I replaced it with a K&N, but it stuck out of the front so I had to fab something different for the snorkel. I also got all the ground wires sheathed and covered, and replaced the wire from the alternator to the starter and the starter to the fuse block... that cleared up my voltage drop issue. Finally, I replaced the intake with a 3" setup using stylinmotors hoses and T-bolt clamps and replaced all the boost/vacuum lines with stylinmotors hoses. Sooo, here's my oldest modeling all my underhood modifications:3" intake, pipercross filter, silicone hoses, T-bolt clamps, battery relocated to trunk, T3/T4 turbo with heat shield, Tial wastegate, RC engineering 550cc injectors, FMIC with hardpiping, Apexi blowoff valve, custom carbon fiber spark plug cover, Ohlins suspension, strut tower brace, grounding cables, poly bushing, etc.This is in performance so I can give some props to Stylinmotors, by the way -Jon Link to comment Share on other sites More sharing options...
Evil E Posted July 2, 2006 Report Share Posted July 2, 2006 Sweet. Awesome looking engine-bay. Link to comment Share on other sites More sharing options...
Zulu Posted July 2, 2006 Report Share Posted July 2, 2006 What manifold & stock bottom end? Cute kid. Link to comment Share on other sites More sharing options...
VolvoFan Posted July 2, 2006 Author Report Share Posted July 2, 2006 What manifold & stock bottom end? Cute kid.Stock manifold with T3 flange, stock bottom end. It's still not tuned right anyways so I'm not going to blow it up anytime soon.-Jon Link to comment Share on other sites More sharing options...
WhiteT5 Posted July 2, 2006 Report Share Posted July 2, 2006 Damn ME7. Oh yeah, Swedish Mikes knows how to make the N/A cams work on the VVT cars, but I don't remember any specific details. Link to comment Share on other sites More sharing options...
Jaxx Posted July 2, 2006 Report Share Posted July 2, 2006 is it just me or does it look like you had oil all over the head? Link to comment Share on other sites More sharing options...
merlin390 Posted July 2, 2006 Report Share Posted July 2, 2006 is it just me or does it look like you had oil all over the head?its the protetive clear coat coming off. Link to comment Share on other sites More sharing options...
s70turbo1998 Posted July 2, 2006 Report Share Posted July 2, 2006 the kid increases torque right? Link to comment Share on other sites More sharing options...
Evil E Posted July 2, 2006 Report Share Posted July 2, 2006 the kid increases torque right?No HP. Link to comment Share on other sites More sharing options...
s70turbo1998 Posted July 2, 2006 Report Share Posted July 2, 2006 ah dammit i always get that confused... Link to comment Share on other sites More sharing options...
RussB Posted July 2, 2006 Report Share Posted July 2, 2006 Great pictures! You have a beautiful daughter, CONGRATS :) Link to comment Share on other sites More sharing options...
Zulu Posted July 2, 2006 Report Share Posted July 2, 2006 Stock manifold with T3 flange, stock bottom end. It's still not tuned right anyways so I'm not going to blow it up anytime soon.-Jonexternal wg off stock manifold? got pics? Link to comment Share on other sites More sharing options...
VolvoFan Posted July 2, 2006 Author Report Share Posted July 2, 2006 No HP.only when she gets out and helps push :) Link to comment Share on other sites More sharing options...
VolvoFan Posted July 2, 2006 Author Report Share Posted July 2, 2006 external wastegate off stock manifold? got pics?The new turbo is a 5-bolt flange... the flange plate has two separate holes in it... a main hole for all the gasses coming from the turbine, then a smaller hole about 1" in diameter (actually, I flattened it out so it's more like an oval) that runs through a separate pipe to the wastegate. The pipe out the other side of the wastegate returns to the downpipe. In other words, the stock manifold is unchanged as far as the wastegate is concerned.-Jon Link to comment Share on other sites More sharing options...
Zulu Posted July 2, 2006 Report Share Posted July 2, 2006 Ah yeah duh, >_<. Link to comment Share on other sites More sharing options...
