Matts 850 GLT Posted July 3, 2006 Report Share Posted July 3, 2006 HelloI am running a 95 855 2.4 10v. It has had little use over the last 7 years and so I am recommissioning it.I get a few moments of black smoke on start up (only when cold) and it clears and runs normal after 5 mins. I put new plugs and air filter in so what is causing the black smoke.Mileage is 70,000 so I don't think the motor is too worn.Matt Link to comment Share on other sites More sharing options...
javadoc Posted July 3, 2006 Report Share Posted July 3, 2006 Hmmm... Mine does that on start up, always has. Well, I just get a small puff of black but nothing more. I've been driving it like that for... 60k miles and no issues. Link to comment Share on other sites More sharing options...
EvilBrick Posted July 3, 2006 Report Share Posted July 3, 2006 worst thing for a car is to just sit. The seals have no lubrication from the oil and start to rot. Link to comment Share on other sites More sharing options...
TEKVOLVO Posted July 3, 2006 Report Share Posted July 3, 2006 i've had black smoke from injectors leaking. fuel leaking out over night will build in cylinders and burn off on start up. if it's blueish smoke, check pcv system. oil bulid up in system, or valve/turbo seals can seep over night. if you suspect injector leak down you can pull the rail and slip in a piece of cardboard between injector heads and intake. check for fuel stains in the morning. i've had good luck with injector cleaning with a BG or equivalent type service where car runs on the injector cleaner w/o fuel. also intake and throttle service can help too. Link to comment Share on other sites More sharing options...
ziddey Posted July 4, 2006 Report Share Posted July 4, 2006 i've had black smoke from injectors leaking. fuel leaking out over night will build in cylinders and burn off on start up. if it's blueish smoke, check pcv system. oil bulid up in system, or valve/turbo seals can seep over night. if you suspect injector leak down you can pull the rail and slip in a piece of cardboard between injector heads and intake. check for fuel stains in the morning. i've had good luck with injector cleaning with a BG or equivalent type service where car runs on the injector cleaner w/o fuel. also intake and throttle service can help too.That's a great possibility.Black isn't usually too bad since it just means you're having an ultra rich condition. Could be a leaking injector. Could be some other cold start mechanism. But black smoke almost never means your engine deteriorated persay Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted July 4, 2006 Author Report Share Posted July 4, 2006 ThanksI had wondered about the injectors. How elso can I diagnose them as leaking?Matt Link to comment Share on other sites More sharing options...
ziddey Posted July 4, 2006 Report Share Posted July 4, 2006 I'm not sure about this but I'd imagine that you could just check pressure at the fpr and if it's down to 0, that means your injectors probably leaked them in. Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted July 5, 2006 Author Report Share Posted July 5, 2006 ThanksMatt Link to comment Share on other sites More sharing options...
TEKVOLVO Posted July 5, 2006 Report Share Posted July 5, 2006 I'm not sure about this but I'd imagine that you could just check pressure at the fpr and if it's down to 0, that means your injectors probably leaked them in.you should hold at least 2bar of fuel pressure for 20min, the one way valve in line can also cause drop in rest pressure. you'll know it if you have severe leaking injectors, because you will be getting a hard start after car has sat for 10-15 min. a slight leak down, like over night or an injector with a poor spray pattern is a more likley fault, but it could be several things. try cleaning 'em out, might just work. also make sure your oil is not contaminated with fuel. Link to comment Share on other sites More sharing options...
