bapx17 Posted July 9, 2006 Report Share Posted July 9, 2006 I have a 1999 S80 T-6 and i want to put my subs and amps in my car, but i dont know the wirein to well, id like to know if some one know where i can get info about the wireing, in the car or can help me im used to V.W's since i have a 1969 V.W Karmann Ghia Thanks for reading this i hope to get some help Thanks again BAP 1999 S80 T-6 Volvo1969 V.W Karmann-GhiaNew Alliance Designswww.bapx17.vze.com Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 11, 2006 Report Share Posted July 11, 2006 Do you have a factory Head unit?here's a write up for the 850 but same concept.http://www.volvospeed.com/obd2/subinstall1.htm Link to comment Share on other sites More sharing options...
tedt-5 Posted July 11, 2006 Report Share Posted July 11, 2006 I just had a sub wired in my 98 s70 with OUT replacing the deck. I got this part that wires to your front speakers and gives you RCA outputs. I ran a simple MTX thunder to a kicker 12 and it sounds great! http://peripheralelectronics.com/web/loc.asp Look for the "P50" Link to comment Share on other sites More sharing options...
the underlørd Posted July 11, 2006 Report Share Posted July 11, 2006 all the wiring is custom, it's not like there's a kit for your car..run wires from battery to fuseblock, to amp, ground amps, remote turn on lead, amps to speakers, yadda yadda. Link to comment Share on other sites More sharing options...
bapx17 Posted July 12, 2006 Author Report Share Posted July 12, 2006 I have the orig head unit, the thing is when i did the wireing for my V.W, all i did was take the two wires form the unit *cd player* to my amp, and forum my amp one to grd and one to batt, but in a volvo. I have it in my car like this so u know wut im doing, i have the amp, and two lines comeing out of it one is RED and one is BLACK, the 12v (red) is not put in since i dont have my subs in, i dont know if i need to wire my amp to my head unit, or jus to the fuze box, and and how to i wire it to the fuze box, i have been to the site with the red volvo, its how i got here :) but i want and tryed to do this and kinda got lost, all i reallly need is wire dragm or a pic and something like that and i can do it, I jus want to make sure i need to wire, and do so i dont mess up my car, and yeah. one more ? if u dont mine, my amp im my old car, with it was on it had a green light, when it had 12vs to it, now when i put the 12vs on it does not have a green light, did i blow it somehow? Thanks for ur help again i hope u can understand me rightin http://www.cardomain.com/member_pages/show...266_90_full.jpgThere is a pic of the sub and amp im putting in.BAP Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 12, 2006 Report Share Posted July 12, 2006 The amp won' turn on until you have the remote/12V signal wire connected to it. It's just a small wire to tell the amp to turn on. The factory amp should be under the drivers seat, if you slide it all the way forward you should be able to see it. Here is the VADIS Instrucitons on how to remove it.Move the seat to the front upper position.Remove the air duct.Fold the floor carpet to one side at the front mounting.Remove the screw from the front mounting.Fold out the floor carpet at the rear mounting.Remove the screw from the rear mounting.Pull out the amplifier slightly.Disconnect the three connectors.Install:In reverse order.Hint: Wedge the screw in the sleeve using a little paper to insert the screw properly. Otherwise there is a risk of losing it.and the round plug on it comes from the Head unit. The center wire in there is the remote power turn on, you might be able to tap into that to get a amp signal.D6#47Control signal (off / on) amplifierIf this seems like to much work take it to a shop, I probaly would because newer radios are a pain in the ALL GLORY TO THE HYPNOTOAD half the time. Link to comment Share on other sites More sharing options...
bapx17 Posted July 13, 2006 Author Report Share Posted July 13, 2006 Thanks i will have to take a look if it is to much then i will, i jus like workin on my own car then haveing someone do it.The thing is about the amp is i had 12v runnin to forum the batt and it still did not turn on, now did i fire it or it jus wont try on till its told to? thanks again for all ur help Link to comment Share on other sites More sharing options...
bapx17 Posted July 13, 2006 Author Report Share Posted July 13, 2006 Yeah i went and looked at that amp its on the pass side, and its really hard to get to and yea, so i think im jus goin to have to take it in, cuz i dont know wut they have on there amp so i can hook it up with mine, this way i will see if my amp still works, unless u know wut i have to get to put it in if not thats cool Thanks Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 13, 2006 Report Share Posted July 13, 2006 the factory amo is foor the door speakers.Your amp won't run on with out a remote turn on lead. just for short term test run a small wire from the POstive cable from the battery to the rem plug on your amp and see if it turns on then. Link to comment Share on other sites More sharing options...
bapx17 Posted July 13, 2006 Author Report Share Posted July 13, 2006 i ran a wire for the batt to the "12v" on my amp and the green light still does not turn on, i have looked at the fuzes and there still good, maybe i fried it lol Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 14, 2006 Report Share Posted July 14, 2006 and that 12v was a skinny little plug right, the smallest one on the amp probaly?If it's not turning on in your car take it to a shop to get bench checked. They will let you know if it's shot or not. Link to comment Share on other sites More sharing options...
bapx17 Posted July 14, 2006 Author Report Share Posted July 14, 2006 i think, off the top of my head i dont know, lol but i think the best way is to get it tested.Thanks Link to comment Share on other sites More sharing options...
Owned Posted July 14, 2006 Report Share Posted July 14, 2006 i ran a wire for the batt to the "12v" on my amp and the green light still does not turn on, i have looked at the fuzes and there still good, maybe i fried it lolDid you ground it or only hook up 12v? If you didn't ground it, do so and try again. If it still doesn't work, make sure the line has power in it. Link to comment Share on other sites More sharing options...
bapx17 Posted July 15, 2006 Author Report Share Posted July 15, 2006 yea i did, and the light still does not go on, so i think i blow it, or i jus need to take to someone that knows amps Link to comment Share on other sites More sharing options...
