the underlørd Posted July 11, 2006 Report Share Posted July 11, 2006 Don´t know, wait. /Mike [waits] Link to comment Share on other sites More sharing options...
Swedish Mike Posted July 11, 2006 Report Share Posted July 11, 2006 [waits]TS-1 can be found in 235/30-19 just like the 18" one. Looks really good./Mike Link to comment Share on other sites More sharing options...
the underlørd Posted July 11, 2006 Report Share Posted July 11, 2006 TS-1 can be found in 235/30-19 just like the 18" one. Looks really good./Mike beauty. 235 35 isn't really workin out for me.. thanks for the info mikester. Link to comment Share on other sites More sharing options...
Swedish Mike Posted July 11, 2006 Report Share Posted July 11, 2006 beauty. 235 35 isn't really workin out for me.. thanks for the info mikester.No problemo. I want the 235´s to fill out the rims but also keep a low diameter. I think they will do the job./Mike Link to comment Share on other sites More sharing options...
the underlørd Posted July 11, 2006 Report Share Posted July 11, 2006 No problemo. I want the 235´s to fill out the rims but also keep a low diameter. I think they will do the job./Mike hmm, i wonder about 225-30-19...you think that's a lil too low? (if you can even get 'em) Link to comment Share on other sites More sharing options...
Swedish Mike Posted July 11, 2006 Report Share Posted July 11, 2006 hmm, i wonder about 225-30-19...you think that's a lil too low? (if you can even get 'em)BFG got them, just watch out for the load index cause they are often made for GTI cars = low weight.225´s are just a little bit un-wide for Nebula but I don´t know about other rims.Both Nebula and Pegasus got 235/40-18 from stock and I think 235 looks best./Mike Link to comment Share on other sites More sharing options...
ViperVette Posted July 11, 2006 Report Share Posted July 11, 2006 hmm, i wonder about 225-30-19...you think that's a lil too low? (if you can even get 'em)lol, that would be really small man....Plus, those Nokians have got to be flippin' sweet! I am running 235/35... it does look like alot of meet on the tires w/ the volutions though, I know what you mean. Prolly how that lip is there.on a side note...I have absolutely no rubbing issues of any kind accept when I pass out and wake up to zuluking rubbing my crotch asking me to take him for a ride in my mustang. That kinda kreeps me out.GaryJesus..... Link to comment Share on other sites More sharing options...
shaun Posted July 12, 2006 Report Share Posted July 12, 2006 Thinking about getting some wheels and wondering the exact size/offset for ideal setup with 18's. So far I am thinking something around 18x8 I think offset should be between 34 and 42 but I would like some opinions on 18x7.5 and different offset and spacer options with either size. Right now I am running 225-40-18 and get some bad rubs on my 18x8 wheels. I know this has been talked about over and over and I have read plenty believe me. Just saying ideal setup for minimal rubs and maximum tire area. Opionions please I am thinking about getting some expensive wheels and only want to do it once.I am in the minority in this i know because it does not look as cool as big wheels, but 225 45 16 on 7" 43mm offset gives; no rubbing, no speedo error, good rim protection, good curb protection, more traction(than a 215 od of the same tire), decent ride, and the set up wieghs 10lbs a corner less than titans with 225 45 (52lbs!) did. taking the titans with 225 45 off and putting these on was worth 20 h.p. (butt dyno) and the ride and handling are way better. I also picked up a solid 2mpg at the same time, not to mention the wheels were cheap and so is the tire size (compared to 18") bigger wheels look WAY better though! Link to comment Share on other sites More sharing options...
Gregg Posted July 12, 2006 Report Share Posted July 12, 2006 Thinking about getting some wheels and wondering the exact size/offset for ideal setup with 18's. So far I am thinking something around 18x8 I think offset should be between 34 and 42 but I would like some opinions on 18x7.5 and different offset and spacer options with either size. Right now I am running 225-40-18 and get some bad rubs on my 18x8 wheels. I know this has been talked about over and over and I have read plenty believe me. Just saying ideal setup for minimal rubs and maximum tire area. Opionions please I am thinking about getting some expensive wheels and only want to do it once.18x8: +40 offset, 225/35/18 tires and you should not rub at all with Eibach springs (though I did with my Intrax springs, outside fender liner). +43 or +46 offset will yield less/no rubbing on outer fender if you go really low, but could result in rubbing along inner fender liner. In terms of tire sizes, I wouldn't go smaller sidewall than 225/35...215/40/18 will also work on 18x8 and give a little more protection than 225/35.18x7.5: +43 would probably be best - gives 9mm more clearance on outer fender and 3mm more on inner fender liner than 18x8 +40. This should provide plenty of room to lower the car and you should be able to easily do 225/35 or 215/40.Stay away from 225/40/18 unless you plan on rolling the fenders - otherwise you will rub with a lowered 850- Not sure if you read this, but could be helpful- wheel offset calculator Link to comment Share on other sites More sharing options...
Über855R Posted July 12, 2006 Author Report Share Posted July 12, 2006 18x7.5: +43 would probably be best - gives 9mm more clearance on outer fender and 3mm more on inner fender liner than 18x8 +40. This should provide plenty of room to lower the car and you should be able to easily do 225/35 or 215/40.Stay away from 225/40/18 unless you plan on rolling the fenders - otherwise you will rub with a lowered 850- Not sure if you read this, but could be helpful- wheel offset calculatorDude you are the man! That was all helpfull. I think 18x7.5 +43 FTW unless someone else has anything else to say? What about 235/30/18 tires on a 7.5 rim? Link to comment Share on other sites More sharing options...
Gregg Posted July 12, 2006 Report Share Posted July 12, 2006 Dude you are the man! That was all helpfull. I think 18x7.5 +43 FTW unless someone else has anything else to say? What about 235/30/18 tires on a 7.5 rim?if you can even find it...that is such a small sidewall I wouldn't run it on my car...again, 225/35 is the smallest you should really go Link to comment Share on other sites More sharing options...
CaughtLikeFire Posted July 12, 2006 Report Share Posted July 12, 2006 if you can even find it...that is such a small sidewall I wouldn't run it on my car...again, 225/35 is the smallest you should really goDouble check with the specific tire manufacturer but I'm 99% sure that the minimum approved rim width for a 235/30/18 is 8" so that would be a no-go. Link to comment Share on other sites More sharing options...
Gregg Posted July 12, 2006 Report Share Posted July 12, 2006 Double check with the specific tire manufacturer but I'm 99% sure that the minimum approved rim width for a 235/30/18 is 8" so that would be a no-go.good catch. The only tire I've found in that size is the Toyo Proxes T1R, and the only suitable rim width listed is 8.5". So that is definitely a no-go on a 7.5" or 8" wide wheel. Link to comment Share on other sites More sharing options...
Swedish Mike Posted July 12, 2006 Report Share Posted July 12, 2006 good catch. The only tire I've found in that size is the Toyo Proxes T1R, and the only suitable rim width listed is 8.5". So that is definitely a no-go on a 7.5" or 8" wide wheel.235 will work fine on a 8" rim, just like all OEM Volvo´s./Mike Link to comment Share on other sites More sharing options...
Gregg Posted July 12, 2006 Report Share Posted July 12, 2006 235 will work fine on a 8" rim, just like all OEM Volvo´s./Mikebut 235/30? why does Toyo say 8.5" only? Link to comment Share on other sites More sharing options...
