tallahasseegreys Posted July 18, 2006 Report Share Posted July 18, 2006 Before I order both gears from odometergears.com (I've heard it's best to just go ahead an replace both), I want to make sure that this is definitely the problem.Is there a fuse or any other thing I should check before assuming it's the typical broken gear syndrome?? Link to comment Share on other sites More sharing options...
connorb850 Posted July 18, 2006 Report Share Posted July 18, 2006 Its usually the gear that has a broken tooth, but I have also seen the electric motor that drives the odometer gear go bad too. Link to comment Share on other sites More sharing options...
prasamin Posted July 18, 2006 Report Share Posted July 18, 2006 hard to tell....check the instro cluster fuse under the hood, and if it's good, most likely it's the gears. Link to comment Share on other sites More sharing options...
alonsoc750 Posted August 15, 2006 Report Share Posted August 15, 2006 my odometer has stopped too, but the thing is that it is in kilometers, and i don't know if i can order the two tooths and fix it because maybe the difference with the odometer in miles is the number of tooth in the gear, how can i know?? the stealer wants $250 for the new odometer with part n# 9434098 ... they don't have it in stock so i've been searching but nothing :huh: Link to comment Share on other sites More sharing options...
r850glt Posted August 15, 2006 Report Share Posted August 15, 2006 Good point on the KMH vs. MPH issue, not sure of the answer Link to comment Share on other sites More sharing options...
