Volvoboi24 Posted July 19, 2006 Report Share Posted July 19, 2006 My car is in need of a new clutch, and I was wondering do I need to machine the flywheel? the shop i usually take my volvo to is asking if i want to have it done, and Im not sure if its really nessecary... what are the benefits of machining it?Also, does 600 for labor (w/o machining the flywheel) sound about right? I have also heard about people putting in the 850R? clutch on their M56H transmission. Anyone know the part number for the clutch kit? Thanks in advance. Link to comment Share on other sites More sharing options...
the underlørd Posted July 19, 2006 Report Share Posted July 19, 2006 Anyone know the part number for the clutch kit? Clutch and Plate272218 Link to comment Share on other sites More sharing options...
Volvoboi24 Posted July 19, 2006 Author Report Share Posted July 19, 2006 Is there anything else I should replace while having it done? Do i need a new "throw out bearing" as well? an alignment tool? Link to comment Share on other sites More sharing options...
the underlørd Posted July 19, 2006 Report Share Posted July 19, 2006 Is there anything else I should replace while having it done? Do i need a new "throw out bearing" as well? an alignment tool? Toolsthere's the press tool 999 5662-5 centering tool999 5663-3Throw Out bearing (release bearing)9181651 (9163506)(9143472) Link to comment Share on other sites More sharing options...
shaun Posted July 20, 2006 Report Share Posted July 20, 2006 Is there anything else I should replace while having it done? Do i need a new "throw out bearing" as well? an alignment tool?rear main seal might be worth it while it is open. Link to comment Share on other sites More sharing options...
Spoony Posted July 20, 2006 Report Share Posted July 20, 2006 Just out of curiosity, how many miiles were on it before it went? Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted July 20, 2006 Report Share Posted July 20, 2006 Just out of curiosity, how many miiles were on it before it went?I had 50k on my T5 before the first clutch slipped and I just did the 98NA with 85,000. Always recommend changing the throwout bearing too. No use having to go back in again for an extra $100 or so. :rolleyes: Link to comment Share on other sites More sharing options...
Volvoboi24 Posted July 26, 2006 Author Report Share Posted July 26, 2006 Just out of curiosity, how many miiles were on it before it went?110,000Miles... still drivable but slips once in a while under WOT Link to comment Share on other sites More sharing options...
BlackT5 Posted July 26, 2006 Report Share Posted July 26, 2006 You might consider switching to the singlemass flywheel and then use the 850R clutch kit. You might experience some chatter at idle. Search for flywheel, there's tons of info on this. Link to comment Share on other sites More sharing options...
