tallahasseegreys Posted July 20, 2006 Report Share Posted July 20, 2006 So yeah, I had just started the car at a friend's house. I drove about 1/2 mile and noticed the dreaded up arrow was on when I was stopped at a light. I made sure I was in D and not 3. When the light turned green, I stepped on the gas and noticed that the acceleration was poor. I got her up to about 45 and drove to the next light about 2 miles away. Everything seemed ok during that 2 miles.When I got to the light, I turned the car off for about 10 seconds and restarted. UP arrow never came on, and the car accelerated normally after that. This was 2 days ago, and I haven't seen the arrow since.Should I be worried??? Was this just a random thing???I checked the tran fluid after driving home yesterday. Parked it in the garage, went thru all the gears, let her run for a minute or so and then checked the fluid level. It is a tad bit over the max line. Should I drain some out to get it back to within the HOT level? Could this have contributed to the UP arrow appearance??Thanks! Link to comment Share on other sites More sharing options...
connorb850 Posted July 20, 2006 Report Share Posted July 20, 2006 Have you checked transmission codes? Link to comment Share on other sites More sharing options...
MikeG Posted July 20, 2006 Report Share Posted July 20, 2006 Did the 94 models have a winter/wet mode button? Link to comment Share on other sites More sharing options...
tallahasseegreys Posted July 20, 2006 Author Report Share Posted July 20, 2006 No I did not check tranny codes cause the check engine light didn't come on. Could there be codes anyway??Yes, there is a winter button, and it was not on. Link to comment Share on other sites More sharing options...
MikeG Posted July 20, 2006 Report Share Posted July 20, 2006 Are you sure the winter button was not on? I've inadvertantly tapped the button before and didn't notice until I saw the arrow light. The button (and the arrow light) will reset to normal position (off) after the car is turned off, so it sure sounds like that's what happened. Next time it happens, try to push the selector buttons and see if you can turn off the light... you might just have a faulty selector switch or - even simpler - the contacts might need to be cleaned.Oh, and just because the button's light was not illuminated does not mean it was not pressed... HTH Link to comment Share on other sites More sharing options...
ziddey Posted July 20, 2006 Report Share Posted July 20, 2006 you hit the winter button Link to comment Share on other sites More sharing options...
shaun Posted July 20, 2006 Report Share Posted July 20, 2006 you hit the winter buttonditto.. i did the same a couple times. Link to comment Share on other sites More sharing options...
tallahasseegreys Posted July 20, 2006 Author Report Share Posted July 20, 2006 Are you sure the winter button was not on? I've inadvertantly tapped the button before and didn't notice until I saw the arrow light. The button (and the arrow light) will reset to normal position (off) after the car is turned off, so it sure sounds like that's what happened. Next time it happens, try to push the selector buttons and see if you can turn off the light... you might just have a faulty selector switch or - even simpler - the contacts might need to be cleaned.Oh, and just because the button's light was not illuminated does not mean it was not pressed... HTHThank God!!! I saw that Darn arrow and a bunch of dollar signs started dancing around in my head.Thanks a lot guys! Link to comment Share on other sites More sharing options...
