TheMan5952 Posted August 9, 2006 Report Share Posted August 9, 2006 wouldnt that throw on an ABS/TRACS light? how trhe hell do i check it? i looked in the haynes for the car, but the haynes is really quite vague and useless.Not always, you gotta remember cars are funky sometimes. they could tie into a common resistor that goe to the speedo/ECU output and it could be going there so the ABS/TRACS system thinks everything is fine and your ECU doesn't know the difference. Only you do.Maybe try what Homer said.If not, I would suspect the ABS unit is bad. Use a heat gun to loosten the seal on the unit, you'll see the broken solder joint, just remove the old stuff and re-solder. Use a silicone sealant on the ABS unit afterwards to close it back up. Link to comment Share on other sites More sharing options...
Anthrpicdecadnce Posted August 9, 2006 Author Report Share Posted August 9, 2006 Not always, you gotta remember cars are funky sometimes. they could tie into a common resistor that goe to the speedo/ECU output and it could be going there so the ABS/TRACS system thinks everything is fine and your ECU doesn't know the difference. Only you do.Maybe try what Homer said.dammit. why is this so complex??? Link to comment Share on other sites More sharing options...
TheMan5952 Posted August 9, 2006 Report Share Posted August 9, 2006 dammit. why is this so complex???Welcome to Modern engineering. Link to comment Share on other sites More sharing options...
