Über855R Posted August 3, 2006 Report Share Posted August 3, 2006 Look what I got last night! Polished valve cover, polished intake manifold, polished fuel rail/cover, bored throttle body,and a couple other things I haven't pictured.Oh yeah, NA cams also. Plus I hung out with scott for a while, got cought up on the progress with project 6. That 850 is going to be sooo sick! Mine isn't turning out too bad either. Yes that was me who jumped on the TB and intake mani the other day. Good score, finally sitting around checking volvospeed over and over paid off. :D Link to comment Share on other sites More sharing options...
fastboy Posted August 3, 2006 Report Share Posted August 3, 2006 shiny bits never hurt :tup: Link to comment Share on other sites More sharing options...
Guest S7013g Posted August 3, 2006 Report Share Posted August 3, 2006 Pretty Link to comment Share on other sites More sharing options...
Gioseppe Posted August 3, 2006 Report Share Posted August 3, 2006 shineyyyyy.i like.where did you get the cam cover? junkyard? i wouldn't reccommend swapping cam covers... bad things happen to the journals. but if you got the head to go with it then score! do it! Link to comment Share on other sites More sharing options...
Über855R Posted August 3, 2006 Author Report Share Posted August 3, 2006 shineyyyyy.i like.where did you get the cam cover? junkyard? i wouldn't reccommend swapping cam covers... bad things happen to the journals. but if you got the head to go with it then score! do it!You think I should wait on that one? Just hang onto it and install later with a new motor/head. I thought I could throw in the na cams and do it at the same time. People have problems removing the valve covers? MOre info please? Link to comment Share on other sites More sharing options...
Ivanfbi Posted August 3, 2006 Report Share Posted August 3, 2006 valve covers and heads are built to match each other, that's why all of them are unique, thus making it really hard to swap. Link to comment Share on other sites More sharing options...
PullMyFinger Posted August 3, 2006 Report Share Posted August 3, 2006 The upper and lower cam halves are machined together as a matched set.It might fit, might not. Might leak, might not. Might bind and crack, might not. Link to comment Share on other sites More sharing options...
Mesoam Posted August 3, 2006 Report Share Posted August 3, 2006 i'de say absolutely forget the valve cover (cam cover, whatever just don't call it a spark plug cover)i say while its off send the manifold out for jet hot coating (only about $150) Link to comment Share on other sites More sharing options...
CRK Posted August 3, 2006 Report Share Posted August 3, 2006 Well if your going to be swapping intake, cam cover, n/a cams, and soforth...... Pull the head and have a machine shop match the two. It can't be that much more work ( to remove the head) can it? Link to comment Share on other sites More sharing options...
BeachRat Posted August 3, 2006 Report Share Posted August 3, 2006 I would agree with those suggesting either a machinist matching your valve cover to the head, or polishing your own. I can't say I knew that before reading this, but I can tell you how messed up your cams will be if those bearing journals aren't aligned well. :ph34r: Link to comment Share on other sites More sharing options...
Über855R Posted August 4, 2006 Author Report Share Posted August 4, 2006 Well I think I am going to put the manifold on and the TB. I will save the valve cover and cams for a later date. Motor build is coming, start collecing parts for a greater future for my volvo. Link to comment Share on other sites More sharing options...
83' turbo Posted August 4, 2006 Report Share Posted August 4, 2006 o hell yea bro, looks awesome Link to comment Share on other sites More sharing options...
Evil E Posted August 4, 2006 Report Share Posted August 4, 2006 Nice score! How is the tranny coming along? Link to comment Share on other sites More sharing options...
Über855R Posted August 4, 2006 Author Report Share Posted August 4, 2006 Nice score! How is the tranny coming along?Hopefully trans should be in by next friday. Hopefully... Link to comment Share on other sites More sharing options...
Evil E Posted August 4, 2006 Report Share Posted August 4, 2006 What did you decide to go with? Level 10, or to wait it out? Anyway, I bet you're jonesing to drive her again. Link to comment Share on other sites More sharing options...
