Über855R Posted August 4, 2006 Report Share Posted August 4, 2006 I am going to change my thermostat. Is there an optional thermostat that opens at a lower temperature to keep the motor slightly cooler. It seems like a cheap way to keep temps down if there is another one available. Anybody? Link to comment Share on other sites More sharing options...
WhiteT5 Posted August 4, 2006 Report Share Posted August 4, 2006 87° one from FCP Groton is what I'm running and seems to work great. You can get an 80° one from Autotech in Sweden, but I don't know who's actually making the unit. I can't see the need for such a t-stat though unless you've got some serious stuff under the hood. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 4, 2006 Report Share Posted August 4, 2006 PLus it Fs your A/F and anything below about 85 is going to set a CEL Link to comment Share on other sites More sharing options...
Boosted5cyl Posted August 4, 2006 Report Share Posted August 4, 2006 Good to know thanks Che', the StarQuest DSM guys run lower stats too, referring to temps some as low as say 10-20 degrees lower if you can find um, but the CEL thing is that catcher ! have a good weekend yall. by the way what's the stock stat open@ anyhew ? Link to comment Share on other sites More sharing options...
prasamin Posted August 4, 2006 Report Share Posted August 4, 2006 Good to know thanks Che', the StarQuest DSM guys run lower stats too, referring to temps some as low as say 10-20 degrees lower if you can find um, but the CEL thing is that catcher ! have a good weekend yall. by the way what's the stock stat open@ anyhew ?90 degrees or 87 depending on which you have. i replaced my stock one with an 87 from FCP/Vernet Link to comment Share on other sites More sharing options...
