Texas850Turbo Posted August 10, 2006 Report Share Posted August 10, 2006 Mine's at 10 inches mercury idling in drive and with A/C on.....which is a lot of the time....isn't that bad cuz that shows the engine is working a lot harder than it should? Link to comment Share on other sites More sharing options...
sion Posted August 10, 2006 Author Report Share Posted August 10, 2006 What does it read in neutral with the A/C off?The reading you have noted is with the engine under load - eg. in gear & with the A/C compressor also loading up the engine. Link to comment Share on other sites More sharing options...
James100 Posted August 10, 2006 Report Share Posted August 10, 2006 I found this about vacuum numbers. Vacuum Readings. There is a chart at the bottom of the webpage that tells what the numbers mean. Link to comment Share on other sites More sharing options...
sion Posted August 11, 2006 Author Report Share Posted August 11, 2006 Great info James, well done. :) Link to comment Share on other sites More sharing options...
rodrigo Posted August 11, 2006 Report Share Posted August 11, 2006 I found this about vacuum numbers. Vacuum Readings. There is a chart at the bottom of the webpage that tells what the numbers mean.some one pin that!! Link to comment Share on other sites More sharing options...
James100 Posted August 12, 2006 Report Share Posted August 12, 2006 Autometer 3301 vacuum/boost gauge showing vacuum at 21 to 21.5 at idle in park and neutral in an autometer cup on the steering column. Just experimenting with location of the gauge. Probably will put it in a triple pod eventually. It is sitting there attached with velcro. You can watch it very well in this location. Got it working 1 week ago thanks to information from volvospeed.At Idle in parkSitting on steering column Link to comment Share on other sites More sharing options...
MadeInJapan Posted August 12, 2006 Report Share Posted August 12, 2006 Just got mine in...17~18 at idle (AC off and in P), boosting to 15 and spiking a bit higher. Everything working right! Link to comment Share on other sites More sharing options...
TM850R Posted August 12, 2006 Report Share Posted August 12, 2006 Man do I need to fix my vacuum leak. Damn pesky elbows... Link to comment Share on other sites More sharing options...
James100 Posted August 12, 2006 Report Share Posted August 12, 2006 Man do I need to fix my vacuum leak. Darn pesky elbows...Another place to check.This is an old pic of my vacuum tree before I cleaned up someones bad work with new elbows. But in this pic look where the oetiker clamps are circled in yellow. Both those clamps were loose and the one on the tree was very loose. The thing is they looked fine when you looked at them but moved when you touched them. They are gone now with American style clamps in their place. Link to comment Share on other sites More sharing options...
sion Posted August 14, 2006 Author Report Share Posted August 14, 2006 I mounted my Autometer 3303 (Sport Comp) in a cup on top of the dash, just near the windscreen pillar.I'll post a pic tomorrow. Link to comment Share on other sites More sharing options...
