DeLupo Posted August 11, 2006 Report Share Posted August 11, 2006 Can anyone tell me where I can purchase a service/repair manual, paper or CD, for my 2000 Volvo S70. I have looked since I purchased the vehicle new six years ago, and the only manual I can find is at Volvo, which is a complete set for 4 grand. I need to replace my timing belt, water pump and both tensioner and idler pulleys. Bay 13 shows a 850 timing belt replacement which looks close to my setup, but does not discuss the water pump and mechanical tensioner pulley adjustment. I plan on replacing both the pulleys and waterpump, I like to do it right the first time, and I am not sure how to set the tension and the water pump is difficult to see. I am a little hesitant to attempt without some instruction or diagrams.Thanks Link to comment Share on other sites More sharing options...
the underlørd Posted August 11, 2006 Report Share Posted August 11, 2006 Link to comment Share on other sites More sharing options...
3p141592654 Posted August 11, 2006 Report Share Posted August 11, 2006 Unofficially, you can sometimes find the older VADIS DVDs for sale on Ebay. Then you need to use your search engine to find a valid sysadm passwd, and also instructions to fix the date codes, which will have all expired. If your not a computer geek, it may all be too much hassle. Other than that, you can buy a subscription service from Volvo for a few days, but the cost of that is also pretty high, but not as bad as $4k! There are some Hanes manuals around too, but they tend to be the European models (i.e. there is a V70 Hanes manual). They are not usually as good as the VADIS instructions though. Link to comment Share on other sites More sharing options...
Jarhead Posted August 13, 2006 Report Share Posted August 13, 2006 It is really pretty straight forward and simply once you get in to it. Bay 13's directions are great with minor variations for the mech tensioner. Here is a link for the Mech tension instructions.http://www.volvospeed.com/Repair/ManualTensioner.phpI just completed all you are doing on a 99 V70 GLT and had an easy time with the help from the forum. Get in and do it and help will be there if you need it. Link to comment Share on other sites More sharing options...
DeLupo Posted August 24, 2006 Author Report Share Posted August 24, 2006 Can anyone tell me where I can purchase a service/repair manual, paper or CD, for my 2000 Volvo S70. I have looked since I purchased the vehicle new six years ago, and the only manual I can find is at Volvo, which is a complete set for 4 grand. I need to replace my timing belt, water pump and both tensioner and idler pulleys. Bay 13 shows a 850 timing belt replacement which looks close to my setup, but does not discuss the water pump and mechanical tensioner pulley adjustment. I plan on replacing both the pulleys and waterpump, I like to do it right the first time, and I am not sure how to set the tension and the water pump is difficult to see. I am a little hesitant to attempt without some instruction or diagrams.Thanks Link to comment Share on other sites More sharing options...
DeLupo Posted August 24, 2006 Author Report Share Posted August 24, 2006 Thanks guys, the pictures and tensioner instructions were exactly what I needed. Not sure where you got them, but I appreciate the support. I will perform the replacement myself armed with the info you provided. Thanks again. Link to comment Share on other sites More sharing options...
