Phil94850 Posted August 11, 2006 Report Share Posted August 11, 2006 my lens on my drivers side headlight looks a little foggy on the inside. i noticed some black clips going around the lens. if you remove the clips are you able to remove the lens ??? Link to comment Share on other sites More sharing options...
the underlørd Posted August 11, 2006 Report Share Posted August 11, 2006 there are clips on the bottom, which means the whole light has to come out.ps - don't touch the inside of the lenses. Link to comment Share on other sites More sharing options...
Beiner Posted August 11, 2006 Report Share Posted August 11, 2006 If it's foggy consider an new rubber seal that is between the glass and frame. Make sure the whole housing isn't cracked either. Or the seal where the light goes in isn't bad.Did I cover it all? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted August 11, 2006 Report Share Posted August 11, 2006 The inside of the reg. lens are not coated with that film only the jewel lens insides. Link to comment Share on other sites More sharing options...
the underlørd Posted August 11, 2006 Report Share Posted August 11, 2006 The inside of the reg. lens are not coated with that film only the jewel lens insides. oohh, good call. Link to comment Share on other sites More sharing options...
Phil94850 Posted August 12, 2006 Author Report Share Posted August 12, 2006 thanks fellas :D Link to comment Share on other sites More sharing options...
