turbo11 Posted August 12, 2006 Report Share Posted August 12, 2006 Does anyone know how to access the amp in a 2001 v70. Im trying to install a sub in my car without having to take it into a shop and any suggestions or shortcuts with wireing and anything else are greatly appreciated!Thanks! Link to comment Share on other sites More sharing options...
crazykn Posted August 12, 2006 Report Share Posted August 12, 2006 Are you sure you have a seperate amplifier? If not...http://volvospeed.com/vs_forum/Factory-6-P...eup-t39067.htmlI'm pretty sure the old and new Volvo HUs still have the same plug. Link to comment Share on other sites More sharing options...
NGB Posted August 13, 2006 Report Share Posted August 13, 2006 Someone look in VADIS for this guy. Link to comment Share on other sites More sharing options...
stick70 Posted August 13, 2006 Report Share Posted August 13, 2006 Someone look in VADIS for this guy.or VIDA, either will do... Link to comment Share on other sites More sharing options...
fsrenduro Posted August 15, 2006 Report Share Posted August 15, 2006 crazykn,I tried PMing you but I don't think it went through. Do you, or anyone, know if the 6 pin DIN plug is the same for amplified radios. My hu-613 is internally amplified so would the L/R pinouts still be line level (RCA) or speaker level?I also saw you topic on the 6 pin DIN plug making. What are the other two pinouts that aren't labeled in your picture (rear L/R??). I think the pa-200 and pa-300 amps hook up with a 6 pin DIN but also have an adapter to hook back up to the speaker wire. Anyone know where I can get, or a way to make, that. Link to comment Share on other sites More sharing options...
crazykn Posted August 15, 2006 Report Share Posted August 15, 2006 fsrenduro, check ur PM, my box was full, maybe thats why I didn't get it earlier. Link to comment Share on other sites More sharing options...
vick Posted August 17, 2006 Report Share Posted August 17, 2006 Does anyone know how to access the amp in a 2001 v70. Im trying to install a sub in my car without having to take it into a shop and any suggestions or shortcuts with wireing and anything else are greatly appreciated!Thanks! I am a little confused on why you want to access the factory amp?? If you are adding a sub you will need an aftermarket amp and then you just have to add a High Low adapter on the factory harness of the stero. Run the RCA, power ground and rem and its doneVick Link to comment Share on other sites More sharing options...
