Phil94850 Posted August 12, 2006 Report Share Posted August 12, 2006 i installed a MBC on my car and going to install my boost gauge. where do you guys hook your hose for your boost/vac. for the gauge ? i see the hose going to my stock gauge is it o.k. to just tap that hose or disconnect it and run a seperate hose ?? thanks for any advice !!! Link to comment Share on other sites More sharing options...
James100 Posted August 12, 2006 Report Share Posted August 12, 2006 i installed a MBC on my car and going to install my boost gauge. where do you guys hook your hose for your boost/vac. for the gauge ? i see the hose going to my stock gauge is it o.k. to just tap that hose or disconnect it and run a seperate hose ?? thanks for any advice !!!You can do it either way.You can also not disconnect anything but run the hose from your new boost gauge to the tree. Therefore they are both are on separate lines.I wanted my dash gauge to work also. I just put the T connector into the line under the dash so both turbo gauges are working for now. Link to comment Share on other sites More sharing options...
maiku Posted August 12, 2006 Report Share Posted August 12, 2006 stock gauge vacuum hose is finevacuum tree is fine Link to comment Share on other sites More sharing options...
Phil94850 Posted August 12, 2006 Author Report Share Posted August 12, 2006 thatll work... i wanted both gauges working incase i ever sold the car or whatever. thanks for the help !! Link to comment Share on other sites More sharing options...
