Phil94850 Posted August 12, 2006 Report Share Posted August 12, 2006 the car has 200k on it and it runs great but i always wondered about the boost press. my factory gauge would barely go into the white. I installed the MBC in the pic below and turned it up. I installed a boost gauge and after turning it quite a bit im still only showing about 8-10 pounds of boost and a spike to 12 at times. At idle the gauge is showing about 19 inches of vac and while driving after letting off the gas it goes to about 21 inches of vac. I dont think i have a problem with the vac/boost hose otherwise i would show low vac also. Please take a look at the pics and let me know if ive hooked up something wrong. i tried switching the hoses around on the MBC and it was worst so im sure how i have it now is correct. I plugged the hose coming from the plastic intake and plugged the hose from the intake manifold. any help would be appreciated .... by the way.. the car is completely stock other than the MBC. IMG] Link to comment Share on other sites More sharing options...
James100 Posted August 12, 2006 Report Share Posted August 12, 2006 Yikes. Looks like you will need new silicone vacuum hoses also Phil.What is your gauge in the dash doing now also Phil? When mine in the dash was only moving a little it was because I had some small holes in the line from the tree to the turbo gauge. Near the tree.If your gauge in your dash is not working right now you might have a leak in that line and since you are connected into it with both gauges they will both read low. Link to comment Share on other sites More sharing options...
Phil94850 Posted August 12, 2006 Author Report Share Posted August 12, 2006 james.... my gauge inside is working and so is my new boost gauge. where is the vac. tree your talking about ? yeah... my vac hoses need replacing badly ( next on the list of "to-do's). i was worried i hooked the MBC up wrong. ill check the vac tree when i can find it LOL. im gonna replace all the vac hoses i can find. i hope im not boosting to much. if i had holes in my vac hose would i still be pulling good vacuum ? its showing about 18 inches at idle ? Link to comment Share on other sites More sharing options...
James100 Posted August 12, 2006 Report Share Posted August 12, 2006 Vacuum tree. There is a black plastic cover over it use a 8mm wrench. This is an old pic when I first got the car. The elbows go bad and need to get replaced. Also those clamps in yellow can loosen. Link to comment Share on other sites More sharing options...
James100 Posted August 13, 2006 Report Share Posted August 13, 2006 if i had holes in my vac hose would i still be pulling good vacuum ? its showing about 18 inches at idle ?When I had holes in that line the turbo gauge in the dash would barely move to the left and right. Maybe 1/4" either way. But there was movement. Link to comment Share on other sites More sharing options...
Phil94850 Posted August 13, 2006 Author Report Share Posted August 13, 2006 oh.. ok.. thanks james... ill definetly check it out. mine probably need some attention LOL. thanks for the help. you said yours had holes and that caused your gauge to read incorrectly ?? Link to comment Share on other sites More sharing options...
James100 Posted August 13, 2006 Report Share Posted August 13, 2006 you said yours had holes and that caused your gauge to read incorrectly ??yes the gauge in the dash but I fixed everything. Somehow there was about 3 or 4 little holes in the vac line coming off the tree that runs to the turbo gauge in my dash. I spliced in about 3 feet coming from the tree and everything is working. Link to comment Share on other sites More sharing options...
Phil94850 Posted August 13, 2006 Author Report Share Posted August 13, 2006 heres a pic of my vac. tree. it looks like everything is tight. do u suggest replacing anyways ??hey... i noticed on the left of your vac tree there is a hose coming off it heading back to the eng. compartment. my vac tree its capped off. that vac hose with the yellow stripe was connected to my intake manifold. its capped off at the intake manifold now and i use that hose on my MBC james the hose you replaced for your boost gauge did it have a little rubber then a long plastic hose from the front of the car to the dash then back to rubber up to the factory gauge ? Link to comment Share on other sites More sharing options...
