Volvo Virgin Posted August 25, 2006 Report Share Posted August 25, 2006 Feels like a bad u-joint or a bad ring & pinion in a RWD car.Just did the front,rear and side motor mounts on the bottom of the motor,and running the IPD solid urethane mount up top for the past 1.5 years.The clunking still persists after the new mounts.Most noticeable when not under hard throttle.Like after passing someone and coasting back into your lane,when the car shifts back into 4th it clunks hard.And tho I don't cruise like this normally,I can really notice it if I lock it out in first and drive at about 10-15mph transitioning in and out of the throttle.Could it be the transaxle itself?Other than that the trans shifts/runs great and the car only has 79K on it.Edit:auto trans BTW if it wasn't clear. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted August 27, 2006 Author Report Share Posted August 27, 2006 Feels like a bad u-joint or a bad ring & pinion in a RWD car.Just did the front,rear and side motor mounts on the bottom of the motor,and running the IPD solid urethane mount up top for the past 1.5 years.The clunking still persists after the new mounts.Most noticeable when not under hard throttle.Like after passing someone and coasting back into your lane,when the car shifts back into 4th it clunks hard.And tho I don't cruise like this normally,I can really notice it if I lock it out in first and drive at about 10-15mph transitioning in and out of the throttle.Could it be the transaxle itself?Other than that the trans shifts/runs great and the car only has 79K on it.Edit:auto trans BTW if it wasn't clear.Bump for weak sauce .This is the second maintenance thread I've started this summer that has stumped the board .I miss Rich. Link to comment Share on other sites More sharing options...
rodrigo Posted August 27, 2006 Report Share Posted August 27, 2006 I would start with a trans fluid flush... Link to comment Share on other sites More sharing options...
MarcS Posted August 28, 2006 Report Share Posted August 28, 2006 Where does the clunk sound like it is coming from? If you get it from 3/4 and can duplicate it in first I would think that the tranny flush wouldn't do much, however it can't hurt! An off the wall idea, sometimes a bad shock/strut can cause clunks at odd times. Link to comment Share on other sites More sharing options...
FluidGroove Posted August 29, 2006 Report Share Posted August 29, 2006 ive got the same problems, although i dont know if its transmission related or not. i get the loud clunk on 2/3 upshift. i also know that i need lower engine mounts. heres a pic of the lower currently Link to comment Share on other sites More sharing options...
leurven Posted August 29, 2006 Report Share Posted August 29, 2006 Check endlinks and sway bars links. Could be broken. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted August 29, 2006 Author Report Share Posted August 29, 2006 Thanks for the input guys.I've been chasin this problem for a while and did all the "normal" stuff first thinkin that would solve it.So far IPD solid upper mount,struts,strut mounts,end links,and most recently the front,back and side motor mounts.No clunking on start up like there was,and the mounts were def sagging,but the cluking between 3rd and 4th while under light to no throttle still significant.I was messing around with it again last night while I had a friend in the car,and it is actually making a popping type sound from somewhere up front when I lock it in first and get in and out of the throttle.Any other suggestions? Link to comment Share on other sites More sharing options...
the underlørd Posted August 29, 2006 Report Share Posted August 29, 2006 www.metropolitanmotors.com we have many nice cars for you to replace that one with Rob. love, kevin. Link to comment Share on other sites More sharing options...
leurven Posted August 29, 2006 Report Share Posted August 29, 2006 www.metropolitanmotors.com we have many nice cars for you to replace that one with Rob. love, kevin.You gonna drive it to him Kevin? lol Link to comment Share on other sites More sharing options...
Volvo Virgin Posted August 29, 2006 Author Report Share Posted August 29, 2006 I always have my eyes peeled for S70 T5.If I buy one from you,you're gonna deliver it right? :) Link to comment Share on other sites More sharing options...
FluidGroove Posted August 30, 2006 Report Share Posted August 30, 2006 Thanks for the input guys.I've been chasin this problem for a while and did all the "normal" stuff first thinkin that would solve it.So far IPD solid upper mount,struts,strut mounts,end links,and most recently the front,back and side motor mounts.No clunking on start up like there was,and the mounts were def sagging,but the cluking between 3rd and 4th while under light to no throttle still significant.I was messing around with it again last night while I had a friend in the car,and it is actually making a popping type sound from somewhere up front when I lock it in first and get in and out of the throttle.Any other suggestions?ive got the same poping noise also. all my struts/strut mounts, new vms endlinks are fine. they had a software update for the harsh upshift which required new TCM. not sure if it applies to your car also Link to comment Share on other sites More sharing options...
theForgottenone Posted August 30, 2006 Report Share Posted August 30, 2006 top strut mount or check rubber insulator on coil spring on the bottom against the strut seat tab. If the contact is metal to metal w/o the insulator, you'll get a clunk noise. Link to comment Share on other sites More sharing options...
