Matts 850 GLT Posted August 27, 2006 Report Share Posted August 27, 2006 HelloMy serpentine belt tensioner is noisy with the compressor running, and even quite noisy without.What gives? Do I need a new tensioner?Or is it normal?Matt Link to comment Share on other sites More sharing options...
rp850 Posted August 27, 2006 Report Share Posted August 27, 2006 How old is your belt? I'd change that first before I change the tensioner. A lot easier and solved my noise problems.HelloMy serpentine belt tensioner is noisy with the compressor running, and even quite noisy without.What gives? Do I need a new tensioner?Or is it normal?Matt Link to comment Share on other sites More sharing options...
RussB Posted August 27, 2006 Report Share Posted August 27, 2006 which car we talking about?The tensioner needs to be regularly serviced on a '93 Link to comment Share on other sites More sharing options...
erikv11 Posted August 27, 2006 Report Share Posted August 27, 2006 My serpentine belt tensioner is noisy with the compressor running, and even quite noisy without.What gives? Do I need a new tensioner?Or is it normal?Not normal, in order I'd try (1) new belt then (2) lubricate the tensioner then (3) replace it.The tensioner is super easy to take off (on my 96 850 anyway) for maintenance or replacement, almost as easy as removing the belt. Just two bolts. RussB is right about service, basically it just needs to be lubricated. Look in the service manual that was recently posted here, there are very clear instructions in there. Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted August 27, 2006 Author Report Share Posted August 27, 2006 Not normal, in order I'd try (1) new belt then (2) lubricate the tensioner then (3) replace it.The tensioner is super easy to take off (on my 96 850 anyway) for maintenance or replacement, almost as easy as removing the belt. Just two bolts. RussB is right about service, basically it just needs to be lubricated. Look in the service manual that was recently posted here, there are very clear instructions in there.ThanksHow do you lubricate the tensioner on your 96 model? I was able to do it on the 93 as per the picture in the manual but not on my 95?Matt Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted August 27, 2006 Author Report Share Posted August 27, 2006 which car we talking about?The tensioner needs to be regularly serviced on a '93Thanks RussBMy 93 is gone, I should make my signature clearer. So is the later model (mine is 95my) able to be lubricated? If so, how?ThanksMatt Link to comment Share on other sites More sharing options...
