Justin R32 Posted August 28, 2006 Report Share Posted August 28, 2006 I went to purchase some new rotors online and every site has a different size they say will fit my 98 V70R AWD.I'm looking to replace my stock rotors with a nice looking Cross Drilled rotor. Zimmerman cross-drilled rotors look nice. I'm just doing pads and rotors, so I don't think I want to upgrade calips, etc.... (trying to keep it cheap, slight upgrade)Some sites say the fronts a 302mm, some say they aren't.....What size came stock on a 98 V70R AWD? (front and rear) Where is the cheapest place to purchase? Link to comment Share on other sites More sharing options...
leurven Posted August 28, 2006 Report Share Posted August 28, 2006 Pretty sure you have 280mm fronts. Not sure on rear (standard 98 AWD size). Check against the size of your wheel. If you are running 16s with 280s you will have a big gap. If 302s you will have almost no gap. Link to comment Share on other sites More sharing options...
Boosted5cyl Posted August 29, 2006 Report Share Posted August 29, 2006 they're 280's on all 4 corners If I recall Correctly, goods luck, go to fcpgroton.com or eeuroparts.com, PBR pads squel like hell too, just an FYI. good luck man Link to comment Share on other sites More sharing options...
Justin R32 Posted August 29, 2006 Author Report Share Posted August 29, 2006 awesom, thanks...I keep reading about cross drilled rotors prone to warping.I have a set of Zimm cross-drilled on my BMW and have had no issues with warping. Should I stay away from cross-drilled? ....But, they look so cool!OEM Pads are eXpen$ive !! Link to comment Share on other sites More sharing options...
the underlørd Posted August 29, 2006 Report Share Posted August 29, 2006 i had xdrilled, no warping issues.. the oem pads are super dusty too.. not sure if you care about that, just a fyi. Link to comment Share on other sites More sharing options...
Gioseppe Posted August 29, 2006 Report Share Posted August 29, 2006 front's are 280's...... i'd take this time to upgrade to 302's if you can. Link to comment Share on other sites More sharing options...
Justin R32 Posted August 29, 2006 Author Report Share Posted August 29, 2006 front's are 280's...... i'd take this time to upgrade to 302's if you can.If I could do it for under $300 I would. (302mm rotors, brackets, pads) Link to comment Share on other sites More sharing options...
leurven Posted August 29, 2006 Report Share Posted August 29, 2006 My slotted rotors keep the dust down tremendously. The pads are Mintex I think too. Link to comment Share on other sites More sharing options...
prasamin Posted August 29, 2006 Report Share Posted August 29, 2006 buy some 00R brakes and put them on. Link to comment Share on other sites More sharing options...
Big Will Posted August 30, 2006 Report Share Posted August 30, 2006 If he's running the stock 16s, there's no issue with 302 mm brakes? Is it simply that one would not be able to put 15 inch steel rims on for winter driving with the bigger brakes? Link to comment Share on other sites More sharing options...
Justin R32 Posted August 30, 2006 Author Report Share Posted August 30, 2006 I decided against the 302 upgrade. Someday I'll do a real big brake upgrade, so I want to keep this cheap.I went with 4 Zimmerman x/d/s rotors 280mm$215 for the full setDRT EbAY storeI want to get OEM pads, but where is the cheapest place to get them online? Link to comment Share on other sites More sharing options...
