the underlørd Posted August 28, 2006 Report Share Posted August 28, 2006 anyone? Link to comment Share on other sites More sharing options...
prasamin Posted August 30, 2006 Report Share Posted August 30, 2006 anyone?did you call Jeremy? Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2006 Author Report Share Posted August 30, 2006 ya, i did, he hasn't had to get at them yet.. seems odd that no one else has either.. :( Link to comment Share on other sites More sharing options...
Seamus Posted August 30, 2006 Report Share Posted August 30, 2006 OK!! Pay attention!! First remove the lower rear seat (pull up on the front edge sharply) followed by the seatback, two 8mm nuts (13 mm hex), under the lower edge. Now you can get at all the torx 25 screws around the side panel as well as the plastic clip. When reinstalling the side panal pay particular attention to the upper edge where it joins the window seal. ;) Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2006 Author Report Share Posted August 30, 2006 do you have any daughters that I could marry seamus? Link to comment Share on other sites More sharing options...
DouginDenver Posted August 31, 2006 Report Share Posted August 31, 2006 OK!! Pay attention!! First remove the lower rear seat (pull up on the front edge sharply) followed by the seatback, two 8mm nuts (13 mm hex), under the lower edge. Now you can get at all the torx 25 screws around the side panel as well as the plastic clip. When reinstalling the side panal pay particular attention to the upper edge where it joins the window seal. And then bend the metal bars on the seat bottom back into position, because if it has never been removed before, they will usuallly bend and the seat, once reinstalled, will stick up at the center hump and have a gap. I took an old 12" metal ruler and bent it in a weird way so I can release those seat clips w/o bending the seat. Link to comment Share on other sites More sharing options...
