boostwagboy Posted August 29, 2006 Report Share Posted August 29, 2006 i cant seem to get the wires from the bottom of the a-puillar to under the dash. i am in a serious pickle. Link to comment Share on other sites More sharing options...
boostwagboy Posted August 29, 2006 Author Report Share Posted August 29, 2006 actually my bad i already figured it out! Link to comment Share on other sites More sharing options...
leurven Posted August 29, 2006 Report Share Posted August 29, 2006 Removing dash will be easiest way to make it clean install. Then you can follow the wires up the steering column. Link to comment Share on other sites More sharing options...
prasamin Posted August 29, 2006 Report Share Posted August 29, 2006 Removing dash will be easiest way to make it clean install. Then you can follow the wires up the steering column.you could just take the bolt near the door sill trim out, and the two bolts holding the defogger vent on the dash out, and part of the dash will go forward just a bit....that will allow you to run the wiring in there, and down to under the knee bolster cover, like I did.... Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 29, 2006 Report Share Posted August 29, 2006 Just pull the weather stripping off and tuck them in Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 30, 2006 Report Share Posted August 30, 2006 Just pull the weather stripping off and tuck them in +1 Link to comment Share on other sites More sharing options...
boostwagboy Posted August 30, 2006 Author Report Share Posted August 30, 2006 +1guys i got it all done. thanks Link to comment Share on other sites More sharing options...
