8G5L0T Posted August 31, 2006 Report Share Posted August 31, 2006 I searched and couldnt find anything thta talked about my problem but here it is. About 2 weeks ago my air conditioner system developed a problem. My air blows out cold when set to cold and warm when set to warm but it only comes out the 5 vents that are on the dash. This doesnt vary if the ac setting is switched to the floor or on automatic or on defrost for the front window the air just blows out the front vents. IM thinking a valve or something is jammed or broken. any ideas Link to comment Share on other sites More sharing options...
Guest AlvinL Posted August 31, 2006 Report Share Posted August 31, 2006 Suggest diagnostics done on the ECC to find out where the problem is. You don't say what year is your car. 96 and newer needs a VST but on earlier models, the diagnostic port by the washer fill is where it's at for self diagnosis. Link to comment Share on other sites More sharing options...
8G5L0T Posted August 31, 2006 Author Report Share Posted August 31, 2006 1997 Link to comment Share on other sites More sharing options...
MrWinkey Posted August 31, 2006 Report Share Posted August 31, 2006 could be a damper motor or bad ACC unit assuming it is automatic climate control and not manual. You will need Volvo or an independant with the proper scanner too read the codes for the ACC. Autozone cannot and it's not accessible with an OBDII code reader Link to comment Share on other sites More sharing options...
8G5L0T Posted August 31, 2006 Author Report Share Posted August 31, 2006 im working on getting ahold of tim who fixed jesus's evap at the dealership Link to comment Share on other sites More sharing options...
