Phil94850 Posted September 3, 2006 Report Share Posted September 3, 2006 i recently tuned up my car and it runs strong thru all rpm ranges now and i installed a MBC and gauge. my problem is it still will only boost to about 10 psi mainly about 8 or 9 psi. i can play with the MBC with it turned all the way up the car will spike a little over 10 then drop off to about 7 or 8psi. if i back off on the MBC it will hold between 8 & 10 psi. my question is... this is one of those cheap MBC's off ebay and do u guys think thats my problem or maybe something else ? ive checked vac. lines and such. cant find any problems there. i tried switching the hoses going to the MBC so i know ive got it hooked up correctly. what do u guys think ? Link to comment Share on other sites More sharing options...
RussB Posted September 3, 2006 Report Share Posted September 3, 2006 you keep asking this same question there is a very good chance that the MBC can only hold 10 PSI, due to the spring rate. The drop-off can be due to many things...leaking boost/bad turbo hoses and/or vacuum lines, or a restricted exhaust. Link to comment Share on other sites More sharing options...
Phil94850 Posted September 3, 2006 Author Report Share Posted September 3, 2006 you keep asking this same question there is a very good chance that the MBC can only hold 10 PSI, due to the spring rate. The drop-off can be due to many things...leaking boost/bad turbo hoses and/or vacuum lines, or a restricted exhaust.excuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuussssssssseeeee me russ.. sorry for repeating myself. i didnt realize it. i truly apoligize. thank you for the reply though.. Link to comment Share on other sites More sharing options...
Mesoam Posted September 3, 2006 Report Share Posted September 3, 2006 i think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost upi think you should consider stage zero before even turning boost uphow's that russ? :P Link to comment Share on other sites More sharing options...
POOKDIZZLE Posted September 3, 2006 Report Share Posted September 3, 2006 Check ALL YOUR LINES and make sure you do not have a leak anywhere; when this is done if the MBC still doesn't show any improvements get another one and try it again. ;) Link to comment Share on other sites More sharing options...
RussB Posted September 3, 2006 Report Share Posted September 3, 2006 Check ALL YOUR LINES and make sure you do not have a leak anywhere; when this is done if the MBC still doesn't show any improvements get another one and try it again. +1just replace all original vacuum lines and nipples Link to comment Share on other sites More sharing options...
