KS_R Posted September 7, 2006 Report Share Posted September 7, 2006 my '96 854R would not idle today. it will start, hit about 2k rpms, come down to 1k, and then drop to 500rpms and die. It was fine last night when I drove it home from my run, but now it just won't stay at a steady idle. Link to comment Share on other sites More sharing options...
AGBullit235 Posted September 7, 2006 Report Share Posted September 7, 2006 How is your vacuum? Link to comment Share on other sites More sharing options...
BananaRep Posted September 7, 2006 Report Share Posted September 7, 2006 The first thing to look at is if you got any (ecu) codes. Link to comment Share on other sites More sharing options...
sion Posted September 8, 2006 Report Share Posted September 8, 2006 IAC, air leak somewhere? Link to comment Share on other sites More sharing options...
KS_R Posted September 8, 2006 Author Report Share Posted September 8, 2006 ran an OBDII and it said the MAF is bad. would a MAF keep the car from running? Link to comment Share on other sites More sharing options...
erikv11 Posted September 8, 2006 Report Share Posted September 8, 2006 There is a standard way to test the MAF.If the MAF is bad, then unplugging it won't make the car any worse. But if the MAF is good, then unplugging it will make the misfiring worse.Can you start it, and hold the throttle to run it at slightly higher RPMs, like 1500 or something? Then unplug the MAF. No change means bad MAF, engine stumbles (more) means MAF is working. Link to comment Share on other sites More sharing options...
Randhiv Posted September 8, 2006 Report Share Posted September 8, 2006 thats some good practical advice Erik..good show. Link to comment Share on other sites More sharing options...
KS_R Posted September 8, 2006 Author Report Share Posted September 8, 2006 well the car will start, but then it fumbles down and dies. no i can't even hold it at a higher RPM. Link to comment Share on other sites More sharing options...
erikv11 Posted September 8, 2006 Report Share Posted September 8, 2006 well the car will start, but then it fumbles down and dies. no i can't even hold it at a higher RPM.try unplugging the MAF before you start it, see if that helps. It should still run without a MAF, just rough. Link to comment Share on other sites More sharing options...
