Guest JMH Posted September 12, 2006 Report Share Posted September 12, 2006 I've got a 2001 S60 T5 which is almost up to 105k miles. I know I need a timing belt, but have gotten quotes all over the place. Everything from $360 - for just the belt and tensioners, to $725 for the same, up to $843 for the complete 105K service (including timing belt, etc).Anyone have a clue what REALLY needs to be done at 105K? Link to comment Share on other sites More sharing options...
garbergtsi Posted September 12, 2006 Report Share Posted September 12, 2006 nothing really NEEDS to be done....let er go til she blows Link to comment Share on other sites More sharing options...
s60wot Posted September 13, 2006 Report Share Posted September 13, 2006 nothing really NEEDS to be done....let er go til she blowsthat's a terrible idea. Preventive maintenance is your friend. Link to comment Share on other sites More sharing options...
leurven Posted September 13, 2006 Report Share Posted September 13, 2006 I'd say just do T-belt and have them check the accessory belt and tensioners etc... There may be some work needed there too. Have a Volvo place do it. Link to comment Share on other sites More sharing options...
loseR99 Posted September 13, 2006 Report Share Posted September 13, 2006 i recently bought all of the parts for my 105k service, t-belt - tensioner - idler - water pump - fuel filter, most everything else i've done. Will be doing the service about 10k early too. With something as critical as a timing belt job, i wouldn't wait until i rolled exactly 105k. I'd source some quality parts online and find an independent mechanic. On my s40, parts were $200 total, and i was recently quoted at $300 plus coolant for the labor. I'd also check serpentine belt system, fuel filter, pcv system, plugs, thermostat, etc. If the complete service you mentioned includes the majority of these parts as well as labor costs, i think that you've found the answer. Best of luck with the service. Link to comment Share on other sites More sharing options...
SkyWriter Posted September 13, 2006 Report Share Posted September 13, 2006 do what the maintenance schedule calls for, when it fails down the road it probavly does more damage besides gets you stranded. it's cheap insurance, unless you're poor. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 13, 2006 Report Share Posted September 13, 2006 I'd say just do T-belt and have them check the accessory belt and tensioners etc... There may be some work needed there too. Have a Volvo place do it.W3RD Link to comment Share on other sites More sharing options...
dos_vovo Posted September 13, 2006 Report Share Posted September 13, 2006 If you can afford it - have it done for you.If you can't and have: some grasp of engines in general - the tools - and the time - DIYwww.eeuroparts.com for the partsvolvospeed.com for the cluesdos_vovoroho s70 '99 145kblanco s60 '02 49k Link to comment Share on other sites More sharing options...
Guest arob Posted September 13, 2006 Report Share Posted September 13, 2006 my dad's s60 has 121k on it and it runs fine and we didnt replace anything Link to comment Share on other sites More sharing options...
leurven Posted September 14, 2006 Report Share Posted September 14, 2006 my dad's s60 has 121k on it and it runs fine and we didnt replace anythingWhen the timing belt snaps you won't be very happy. Maintenance is so you aren't left stranded on the side of the road. I would get the work done when Volvo recommends. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 14, 2006 Report Share Posted September 14, 2006 When the timing belt snaps you won't be very happy. Maintenance is so you aren't left stranded on the side of the road. I would get the work done when Volvo recommends.When the timing belt snaps you will be A.) Replacing the engine or B.) Junking the carIt's in the owners manual for a reason.... Link to comment Share on other sites More sharing options...
leurven Posted September 14, 2006 Report Share Posted September 14, 2006 You didn't spend all that money on an XC90 just to let the maintenance slide. Sell the car and buy a honda if you don't want to work on it or do maintenance. Link to comment Share on other sites More sharing options...
oddferkout Posted September 14, 2006 Report Share Posted September 14, 2006 When the timing belt snaps you won't be very happy. Maintenance is so you aren't left stranded on the side of the road. I would get the work done when Volvo recommends.So true. I have a good story about that with the Saab I had before I got my S40. Best change it when Volvo recommends it. The car will treat you much better in the long run. Link to comment Share on other sites More sharing options...
pfeener Posted September 16, 2006 Report Share Posted September 16, 2006 To JMH: Follow the owners manual for the common stuff. Flush the antifreeze and the brake fluid every 2-3 years. Flush the transmission fluid every 50K or so. As you already know, you need to do the timing belt at 105K or when it breaks it will take out the top end of the engine to the tune of $3-4K. You also have to replace the tensioner. The mechanical tensioner is only good for one belt change. It will come apart before the next belt change is due. The water pump is a variable. So folks do replace it and some don't. More than likely it will go the 200K to the next belt change. Link to comment Share on other sites More sharing options...
