USMC850T Posted September 13, 2006 Report Share Posted September 13, 2006 Lately I've been getting noises when i turn the fan on inside the car. It seems as if the noises are due to the fan spinning way to fast, as if it were operating in a vacum. I think something may be plugged up, because that's what it sounds like from outside the car. What filters should I look at to replace? Link to comment Share on other sites More sharing options...
DVolvoguy850T5 Posted September 13, 2006 Report Share Posted September 13, 2006 Lately I've been getting noises when i turn the fan on inside the car. It seems as if the noises are due to the fan spinning way to fast, as if it were operating in a vacum. I think something may be plugged up, because that's what it sounds like from outside the car. What filters should I look at to replace?In your engine compartment there is a cover over the windscreen wipers, there are 5 T25 torx screws holding it down. Remove the right three torx bolds and pull the cover up. On the right hand side of the well under that plastic cover you will see a vent door ( sometimes with a filter over it ) 96 may not have that filter and most likely its clogged with debris etc. Clean out that vent of rubbish and get a cabin filter kit from IPD or FCP Groton. ( you may want to take off the whole cover which requiers removing the Windscreen wipers.Semper Fi Link to comment Share on other sites More sharing options...
