slarti Posted July 7, 2004 Report Share Posted July 7, 2004 I've done a search and I still am unsure what I NEED to replace when doing the timing belt on a 95 850 turbo with 170K, the last timing belt was replaced at 100K. So here are my questions.1. Do I need a water pump?2. Do I need a new tensioner?3. Do I need a idler pulley?4. Should I replace the serpentine belt?5. Is there anything else I should replace while I'm in there?Thanks everyone for your input. :) Link to comment Share on other sites More sharing options...
98V70BASEBOY Posted July 7, 2004 Report Share Posted July 7, 2004 slarti, I would suggest 2, 3, and 4 from your list may be a good starting point. Anything other than those items is probably just overkill, but if you would sleep better at night, do the pump too. I just don't think it is necessary unless there is a definite problem with it. BB B) Link to comment Share on other sites More sharing options...
Pauloil Posted July 7, 2004 Report Share Posted July 7, 2004 would also do tensioner pulley it is cheap... Link to comment Share on other sites More sharing options...
shurgen Posted July 7, 2004 Report Share Posted July 7, 2004 slarti, I would suggest 2, 3, and 4 from your list may be a good starting point. Anything other than those items is probably just overkill, but if you would sleep better at night, do the pump too. I just don't think it is necessary unless there is a definite problem with it. BB I agree Link to comment Share on other sites More sharing options...
DEWFPO Posted July 8, 2004 Report Share Posted July 8, 2004 I agree, at 170K, I would replace both pulleys (tensioner, idler) as well as the belt and the tensioner itself. Water pump should be o.k. unless it leaks, makes unusual noises, or is wobbley or is un-smooth in it's rotation.DEWFPO Link to comment Share on other sites More sharing options...
