wcs1034 Posted September 17, 2006 Report Share Posted September 17, 2006 Let me apologize for bringing up a topic that has been beaten to death but I need some clarification. I have a 2001 V70 T5 with the Geartronic 5-speed automatic transmission. From what I've read, this is an Asian-Warner tranny and the Mobil JWS 3309 is an appropriate substitute from the obscenely expensive Volvo OEM fluid. Before I order a case, is this the right fluid for the Geartronic transmission? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 18, 2006 Report Share Posted September 18, 2006 m Link to comment Share on other sites More sharing options...
FredMc Posted September 18, 2006 Report Share Posted September 18, 2006 Seeing as I work at a dealership all I use is the Volvo stuff but I can tell you that it is synthetic. Hope that helps.For the 90th time, the Volvo fluid is NOT synthetic. It's a myth created by word of mouth in response to the high selling cost of the fluid. The Volvo Fluid is Mobil 3309 just rebadged by Volvo.No where on the Volvo fluid bottle is the fluid called "synthetic" there is NO literature anywhere from Volvo or anywhere saying the Volvo fluid is Synthetic.The cars call for JWS3309 oil specification which is Mobil 3309 at one-forth the cost. I get this from Volvo technicians all the time on different forums calling it "synthetic" and implying it's different and superior to Mobil 3309. I challenge anyone to prove it's synthetic. No one ever has. Read the bottle. It's NOT. It's only a rumor and a bad one. Actually who is to say a "synthetic" fluid is superior anyway. In a lot of transmissions synthetic may prove too slippery. Just use Mobil 3309 and don't look back. Let the others believe it's different but save yourself money and don't buy into the "synthetic" myth. Link to comment Share on other sites More sharing options...
wcs1034 Posted September 18, 2006 Author Report Share Posted September 18, 2006 My question was not as specific as I intended - let me try again.The AW5 normal 5-speed auto is OK with 3309 - is the Geartronic 5-speed OK with it too?Thanks! Link to comment Share on other sites More sharing options...
FredMc Posted September 18, 2006 Report Share Posted September 18, 2006 Geartronic 5 speed AW trans uses Mobil 3309 for sure.It's spec'd to use JWS oil spec 3309 which is Mobil 3309. Link to comment Share on other sites More sharing options...
Alfredo Posted September 19, 2006 Report Share Posted September 19, 2006 oh lets clarifyATF on phaseI for a 4speed tranny, is not synthetic ATF on phaseII for a 5speed tranny is synthetic !!in any case, personally, for good order sake, I wud prefer Volvos stuff. suerte ... Link to comment Share on other sites More sharing options...
Guest Guest Posted September 20, 2006 Report Share Posted September 20, 2006 oh lets clarifyATF on phaseI for a 4speed tranny, is not synthetic ATF on phaseII for a 5speed tranny is synthetic !!in any case, personally, for good order sake, I wud prefer Volvos stuff. suerte ...Alfredo, Alfredo : either you are a very slow learner, or just being a smart azz.Let's clarify and do a search to verify this. Your Wrong!!!All AW transmissions (read 5 speed automatics) use , and that is The Volvo rip off trans fluid which is NOT synthetic. OR, you can use the same fluid Mobil 3309 which is NOT synthetic. (car examples are the S40, S60 and S80 after 02 automatic 5 speed transmissions).4 speed tranny like the 99 through 01 S80's which used a Cadillac GM trans use Dextron III which is also NOT synthetic. Link to comment Share on other sites More sharing options...
FredMc Posted September 20, 2006 Report Share Posted September 20, 2006 oh lets clarifyATF on phaseI for a 4speed tranny, is not synthetic ATF on phaseII for a 5speed tranny is synthetic !!in any case, personally, for good order sake, I wud prefer Volvos stuff. suerte ...Totally wrong. READ and learn.Mobil 3309 and Volvo dealer trans fluids to JWS 3309 oil spec are okay for ALL 5 speed Aisin Warner Trans like those on S60's 40's and some 80's. The fluid is not synthetic nor are they different. They are made by Mobil and rebadged by Volvo. There is not one shread of evidence that AW requires a Special Volvo fluid. Even later model 05 06 and 07 Volvo's don't even call out the Volvo part number for the fluid. Owners manual says to use JWS approved oil for the trans to JWS 3309 oil spec. End of story. Do not spread misinformation on this. I am amazed how this can be misunderstood. Link to comment Share on other sites More sharing options...
theForgottenone Posted September 21, 2006 Report Share Posted September 21, 2006 Seeing as I work at a dealership all I use is the Volvo stuff but I can tell you that it is synthetic. Hope that helps.I might be bad in reading but I seems having trouble to find the word synthetic. Mobil 3309 ATFMobil 3309 specs Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 21, 2006 Report Share Posted September 21, 2006 I might be bad in reading but I seems having trouble to find the word synthetic. Mobil 3309 ATFMobil 3309 specsYeah we have been over that. A LOT. Link to comment Share on other sites More sharing options...
FredMc Posted September 21, 2006 Report Share Posted September 21, 2006 I might be bad in reading but I seems having trouble to find the word synthetic. Mobil 3309 ATFMobil 3309 specsDon't worry dmelviØØ7 delected his post claiming it was synthetic anyway Ignore that obviously.You are correct it IS NOT synthetic nor is it special. It's Mobil 3309 and that is to JWS 3309 oil spec. Moderators should sticky proper transmission requirements to avoid misinformation and confusion that the different models and transmissions and oils can bring. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 21, 2006 Report Share Posted September 21, 2006 Don't worry dmelviØØ7 delected his post claiming it was synthetic anyway Ignore that obviously.You are correct it IS NOT synthetic nor is it special. It's Mobil 3309 and that is to JWS 3309 oil spec. Moderators should sticky proper transmission requirements to avoid misinformation and confusion that the different models and transmissions and oils can bring.Dude, let it go. What are you like 12 years old? BTW You haven't proved shit either. Link to comment Share on other sites More sharing options...
gdizzle Posted September 21, 2006 Report Share Posted September 21, 2006 Don't worry dmelviØØ7 delected his post claiming it was synthetic anyway Ignore that obviously.You are correct it IS NOT synthetic nor is it special. It's Mobil 3309 and that is to JWS 3309 oil spec. Moderators should sticky proper transmission requirements to avoid misinformation and confusion that the different models and transmissions and oils can bring.Delected? WTF is that?Alfredo, Alfredo : either you are a very slow learner, or just being a smart azz.Let's clarify and do a search to verify this. You're Wrong!!!All AW transmissions (read 5 speed automatics) use , and that is The Volvo rip off trans fluid which is NOT synthetic. OR, you can use the same fluid Mobil 3309 which is NOT synthetic. (car examples are the S40, S60 and S80 after 02 automatic 5 speed transmissions).4 speed tranny like the 99 through 01 S80's which used a Cadillac GM trans use Dextron III which is also NOT synthetic.To bad Mr. Smarty pants has horrible grammar. Link to comment Share on other sites More sharing options...
