ThaBigO Posted September 18, 2006 Report Share Posted September 18, 2006 Quick question guys which way do these rotors go on or it doesnt matter?? FOr the Front LEft (drive side) would the Slots be going this way... //// or this way \\\ ??? THanks,OrlandoThese are the brakes.. Link to comment Share on other sites More sharing options...
lax01 Posted September 18, 2006 Report Share Posted September 18, 2006 Quick question guys which way do these rotors go on or it doesnt matter?? FOr the Front LEft (drive side) would the Slots be going this way... //// or this way \\\ ??? THanks,OrlandoThese are the brakes..the boxes should be marked...this should help: Link to comment Share on other sites More sharing options...
ThaBigO Posted September 18, 2006 Author Report Share Posted September 18, 2006 that looks like the Front Passenger side is going this way ///yea im reinstalling them and i forgot which way they go on.... thanks for the pic though! Link to comment Share on other sites More sharing options...
maiku Posted September 18, 2006 Report Share Posted September 18, 2006 the slotted part should be "cutting" into the padshard to describe Link to comment Share on other sites More sharing options...
sion Posted September 18, 2006 Report Share Posted September 18, 2006 I've just fitted slotted Brembos to my R, so here we go:The end of the slot nearest to the outer edge of the rotor should stike the pad first.Hope that helps. ;) Link to comment Share on other sites More sharing options...
Kid_Clean3 Posted September 18, 2006 Report Share Posted September 18, 2006 In your picture, the driver's side is on the left \\\\ & the passenger side on the right ////. Link to comment Share on other sites More sharing options...
erikv11 Posted September 18, 2006 Report Share Posted September 18, 2006 In your picture, the driver's side is on the left \\\\ & the passenger side on the right ////.Actually in the picture, the left side is two frot rotors, and the right side is two rears. The way sion wrote it is good, the rotors that are tilted up are a front passenger's side and a rear driver's side. Link to comment Share on other sites More sharing options...
flyfishing3 Posted September 18, 2006 Report Share Posted September 18, 2006 there ya bmike Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 19, 2006 Report Share Posted September 19, 2006 Mike, now to me, this looks backwards from the description above unless you're going in reverse all the time. Isn't the top of the swirl of holes suppose to hit the brake pads first before the bottom (the part that is closest to the center of the rotor)? Link to comment Share on other sites More sharing options...
sion Posted September 19, 2006 Report Share Posted September 19, 2006 That's correct as per description above - the end of the slot nearest to the outer edge of the rotor should always come into contact with the pad first, which creates a cut & clean effect to help the pad/rotor surfaces maintain their efficiency. Link to comment Share on other sites More sharing options...
maiku Posted September 19, 2006 Report Share Posted September 19, 2006 i've seen various advice when it comes to cross-drilled only, and cross-drilled/slotted rotors, and slotted alone.. Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 19, 2006 Report Share Posted September 19, 2006 That's correct as per description above Okay, so don't know who you're saying is correct. Am I correct or is he correct? As the rotors are on mike's car (picture) and the way the rotor spins, the inner part of the drilled section (closest to the center) are going to hit the pads first with the outer hole (closest to the outer edge of the rotor) following. Link to comment Share on other sites More sharing options...
flyfishing3 Posted September 19, 2006 Report Share Posted September 19, 2006 frank from est, greg, as well as many others during install. that was the agree'd upon way.porsche does it in this direction and thats good enough for me.mike Link to comment Share on other sites More sharing options...
