Über855R Posted September 18, 2006 Report Share Posted September 18, 2006 I am just wondering if anyone has ran 8.5" width 18's on an 850. Iforged just sent me these wheels shown in the showroom. They were supposed to be 7.5 but instead came measuring 8.5 Iforged claims that they will still fit with no issues and to try them before sending back. I say they will rub on the inside since that is where the extra inch in located. So to recap will an 18x8.5+43 wheel fit an 850 without rubs on a 225-35-18 tire. Will a 225 even fit a 8.5" wheel? This is such a PITA three weeks before nationals. Link to comment Share on other sites More sharing options...
POOKDIZZLE Posted September 18, 2006 Report Share Posted September 18, 2006 8.5" seems MAD WIDE man for the 850 wheel wells, I don't want to burst your bubble but unless you plan on driving in a straight line all the time I can't see you not rubbing BAD :( Link to comment Share on other sites More sharing options...
Overboost850 Posted September 18, 2006 Report Share Posted September 18, 2006 I'm reallyy not good with the whole calculating offset thing but when I had pegs I definaely had some room still while running 225s. Not sure if it was a half inch or so but then agin that all depends on the offset. Maybe one of the wheel gurus will step up and tell you for sure. Good luck Link to comment Share on other sites More sharing options...
Gregg Posted September 19, 2006 Report Share Posted September 19, 2006 which part of the wheel did you measure? if you measured outside edge to outside edge and it measure 8.5", then the actual wheel width is 7.5". Link to comment Share on other sites More sharing options...
Über855R Posted September 19, 2006 Author Report Share Posted September 19, 2006 which part of the wheel did you measure? if you measured outside edge to outside edge and it measure 8.5", then the actual wheel width is 7.5".Beleive me I wish that was the case. That would be the easiest fix to just be able to measure differently but I did measure the inside mounting surface. Link to comment Share on other sites More sharing options...
prasamin Posted September 19, 2006 Report Share Posted September 19, 2006 it'll rub and kill unless you roll and stretch.as much as you're trying to make yourself feel better and excited about having them, it will be beneficial to wait and get the correct size.be patient young jedi Link to comment Share on other sites More sharing options...
Über855R Posted September 19, 2006 Author Report Share Posted September 19, 2006 it'll rub and kill unless you roll and stretch.as much as you're trying to make yourself feel better and excited about having them, it will be beneficial to wait and get the correct size.be patient young jediI don't even think rub and stretch will do it. The extra inch is on the inside of the wheel. Anyway thanks Pras I needed to hear that. Link to comment Share on other sites More sharing options...
CAKES855 Posted September 19, 2006 Report Share Posted September 19, 2006 ya I'm with Pras on this on, no way in hell would they fit unless u stretched the living crap out of those fenders and used some decent spacers Link to comment Share on other sites More sharing options...
Greenchunks Posted September 19, 2006 Report Share Posted September 19, 2006 Since youre spending so much on the rims to begin with, get the right size, thats why you got custom rims, so they're exactly what you want. Just wait a little longer and itll be better in the long run. Link to comment Share on other sites More sharing options...
Boomin850 Posted September 19, 2006 Report Share Posted September 19, 2006 Since youre spending so much on the rims to begin with, get the right size, thats why you got custom rims, so they're exactly what you want. Just wait a little longer and itll be better in the long run.Im completely with you on this oneDude, just get the right ones...unless you want your car to be even better and stretch the F$(K outta your fenders!. It'd look sick and we all know it. But for easy, painless, less money, send those bad boys back Link to comment Share on other sites More sharing options...
fromtheshadows Posted September 19, 2006 Report Share Posted September 19, 2006 Either get the right ones, or spacers and run 245's (thatd be cool) in which case you probably will also need to roll. Would be sweet with a wider stance and fatter tires. Link to comment Share on other sites More sharing options...
andrewclee Posted September 19, 2006 Report Share Posted September 19, 2006 I am sure the rears will fit no problem with that offset or a small spacer, it is the fronts you will have to be careful with. I don't beleive the full 1" will be on the inside only, since the offset is from the center of the wheel. I have 18 x 7.5 with et 42, almost the same offset. If you calculate it, it will be 1/2 inch more on the out and inside edge. With that said, I would say do a fitment test with just the wheels and see if it hits anywhere. Link to comment Share on other sites More sharing options...
Yellow95 Posted September 19, 2006 Report Share Posted September 19, 2006 If it is a wagon, I would bet they will fit fine on the rear. Tell them to send you 2 7.5's and roll with the staggered look. I wish I would have done that just for aesthetics.Gary Link to comment Share on other sites More sharing options...
Über855R Posted September 19, 2006 Author Report Share Posted September 19, 2006 If it is a wagon, I would bet they will fit fine on the rear. Tell them to send you 2 7.5's and roll with the staggered look. I wish I would have done that just for aesthetics.GaryI like the staggered look also, but this car is planning on seeing more track time and I think I would preferre the handleing over the aesthetics. If anything it would be better to run the 8.5 front and 7.5 rear but that is just silly. Link to comment Share on other sites More sharing options...
gdizzle Posted September 19, 2006 Report Share Posted September 19, 2006 I like the staggered look also, but this car is planning on seeing more track time and I think I would preferre the handleing over the aesthetics. If anything it would be better to run the 8.5 front and 7.5 rear but that is just silly.so why'd you buy Iforged?! The biggest concern I think you have is will it hit the strut tubes, most likely yes. You will need spacers, probably 20mm for the front. I say, jack the car up and test fit. Link to comment Share on other sites More sharing options...
