Owned Posted September 20, 2006 Report Share Posted September 20, 2006 Brand new, never removed from box. Full 3 year waranty.Is capable of functioning as both a subwoofer or as a midbass driver, depending on how you install it. It can run in as little as .25 cubic sealed and .5 cubic vented. For ported enclosures, tune to 30hz for SQ and 35hz for SPL.Sells for $75 each with "free" shipping on ED's site: http://www.edesignaudio.com/edv2/product_i...;products_id=33$100 + shipping for both, or $50 + shipping each. I don't have an issue with splitting the pair. If you want a shipping quote, just PM me the address they're going to and I'll be able to figure it out.UPS ground (with tracking) only. Average shipping is going to be $5-$7 per driver. Link to comment Share on other sites More sharing options...
Gage Posted September 20, 2006 Report Share Posted September 20, 2006 Ill trade you the dell for them :P Link to comment Share on other sites More sharing options...
Owned Posted September 20, 2006 Author Report Share Posted September 20, 2006 For those interested in the pair, for $20.00 more I will add a set of 7 inch CAE Deflex pads.http://www.cascadeaudio.com/prod/deflex.html Link to comment Share on other sites More sharing options...
maiku Posted September 20, 2006 Report Share Posted September 20, 2006 so i'm assuming they'll fit in 70series front doors, correct?850 will have to be modified a bit? Link to comment Share on other sites More sharing options...
Owned Posted September 21, 2006 Author Report Share Posted September 21, 2006 so i'm assuming they'll fit in 70series front doors, correct?850 will have to be modified a bit?I have never installed one of these in an S70. I would imagine that some slight modification would be nessisary, to accomidate the large magnet. However, these aren't made to be direct replacements like the typical entry level 2-way drivers are. I know that the mounting dept is aprox 3.5 inches. That would be the first thing to check in your car as that is a bit more difficult to overcome than just removing material to make way for the magnet.Also, if you're looking for info on the 850 install, check the A/V stickies. Link to comment Share on other sites More sharing options...
prasamin Posted September 21, 2006 Report Share Posted September 21, 2006 I have never installed one of these in an S70. I would imagine that some slight modification would be nessisary, to accomidate the large magnet. However, these aren't made to be direct replacements like the typical entry level 2-way drivers are. I know that the mounting dept is aprox 3.5 inches. That would be the first thing to check in your car as that is a bit more difficult to overcome than just removing material to make way for the magnet.Also, if you're looking for info on the 850 install, check the A/V stickies.yup, paulr did a rear door install of Eu's in his 850....really nice pics and info. Link to comment Share on other sites More sharing options...
CAKES855 Posted September 21, 2006 Report Share Posted September 21, 2006 are they dual 4 or dual 2 ohm? Link to comment Share on other sites More sharing options...
Owned Posted September 21, 2006 Author Report Share Posted September 21, 2006 dual 2.However, they can be wired to present different loads. If you had only one driver per channel, you can wire the dual 2 as either 2 or 4 ohm. A pair of drivers on a single channel would be limited to 2 ohm, however. You can technically wire two drivers on a single channel to .5 ohm, but it's unlikely you're amp will enjoy that. :) Link to comment Share on other sites More sharing options...
Owned Posted September 21, 2006 Author Report Share Posted September 21, 2006 Link to comment Share on other sites More sharing options...
Owned Posted September 22, 2006 Author Report Share Posted September 22, 2006 Sold these locally today. Thanks guys. Link to comment Share on other sites More sharing options...
