MadeInJapan Posted September 24, 2006 Report Share Posted September 24, 2006 To my surprise, I discovered that this is possible. Not sure what cars this extends to, but someone should try this out. Trouble is that none of the DTC's are explained. I'm suspecting that the codes you get are going to mean the same as what you pull out of the diagnostic junction boxes (B-1 codes all found in the '95 850 downloadable service manual)), but not sure about that.Click on the link below. It will take you to FileFactory. In the middle of the page there's a link you'll click on to use FileFactory Basic for free. This will take you to a second page. Click on Free Download in the middle of that page.http://www.filefactory.com/file/634a6b/Now, when you open the pdf file, scroll down about 2/3 of the way, and the prodedure is there to read the codes from your climate unit without a scan tool! Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 24, 2006 Author Report Share Posted September 24, 2006 Can't believe no one has seen this....bumping up for inspection. Link to comment Share on other sites More sharing options...
Ronny Posted September 24, 2006 Report Share Posted September 24, 2006 I looked at it but I don't trust the content. Are you sure this works? It doesn't make sense. What pdf file are you talking about? Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 24, 2006 Author Report Share Posted September 24, 2006 I looked at it but I don't trust the content. Are you sure this works? It doesn't make sense. What pdf file are you talking about?I trust the content since I uploaded a Vadis document I converted to pdf myself, and the original is from Volvo themselves. Link to comment Share on other sites More sharing options...
erikv11 Posted September 25, 2006 Report Share Posted September 25, 2006 This (about page 5 -onward) looks great for pulling ECC codes. I'll try tonight, presumably get a 1-1-1 but that will convince me it works. I'm afraid to self-adjust the damper motors, they seem to be working fine now ...Good find!The pdf should be permanently hosted somewhere, or just copy-pasted into a post, and pinned. Link to comment Share on other sites More sharing options...
garbergtsi Posted September 25, 2006 Report Share Posted September 25, 2006 this is only for MCC cars....which are somewhat rare, and does not apply to ECC carsnevermind, i see you posted that now, duhhhhh Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 26, 2006 Author Report Share Posted September 26, 2006 This (about page 5 -onward) looks great for pulling ECC codes. I'll try tonight, presumably get a 1-1-1 but that will convince me it works. I'm afraid to self-adjust the damper motors, they seem to be working fine now ...Good find!The pdf should be permanently hosted somewhere, or just copy-pasted into a post, and pinned.I'll see what I can do.After reading through this serveral times, the manual method (without a Volvo Scan Tool) appears to be only for MCC and not ECC. Still, it may help someone here. Hope this works...will try to load her up now. Diagnostic Function: MCCDiagnostic trouble codes (DTCs)Diagnostic functionsThe control module has on-board diagnostics (OBD) which monitors input and output signals.When the control module detects a fault it stores theinformation in the form of a diagnostic trouble code(DTC) and the orange REC button indicator LEDflashes once. Every time the ignition key is turned toposition I or II the orange LED will flash once.If the fault disappears (becomes intermittent) thediagnostic trouble code (DTC) is automatically erasedfrom the control module. In principle the diagnostictrouble codes (DTCs) are erased in the operative cycleafter the control module has registered that thediagnostic trouble code (DTC) has disappeared.Depending on what the diagnostic trouble code (DTC)was that was stored this can occur in different ways. Ifthe indicator LED does not flash there are no DTCsstored and no read out is required.diagnostic trouble codes (DTCs) 2–3–1, 2–3–2, 2–3–5and 2–3–6 the control signal/function is detecteddirectly the ignition is switched on. This means that thediagnostic trouble code (DTC) is erased the next timethe ignition is turned on in the operating cycle after thecycle where the fault disappeared or was corrected.For other diagnostic trouble codes (DTCs) the controlmodule detects the signal/function first when thefunction is activated, as for example when a motor isactivated, or self-adjustment is carried out. This meansthat diagnostic trouble code (DTC) is erased in theoperating cycle after that during which the functionwas activated and registered as OK, in other words thesecond operating cycle.Only when the diagnostic trouble code (DTC) is erasedwill the orange indicator LED stop flashing when theignition is switched on.The Volvo on-board diagnostic (OBD) systemfunctions are activated by pressing the REC button onthe unit. Do not start pushing buttons until 0.5seconds after the ignition has been turned on(positions I or II) and then carry out the requiredcombination within the following 2.5 seconds.Note! If a diagnostic trouble code (DTC) is stored,the indicator LED will flash once. It is now possibleto continue pressing the button to obtain systemresponses.Reading and erasing diagnostic trouble codes (DTCs)The following functions are available:1 reading off diagnostic trouble codes (DTCs)(initiated by pressing two pushes of the button)2 self-adjustment of the damper motors (intitiated bythree pushes of the button)3 erasing diagnostic trouble codes (DTCs) (initiatedby four pushes of the button).Refer to the picture for information on how to initiatethe sequences and how to interpret the flashes from theindicator LED.Note! The REC button must be pressed from theout position (off) to the in position (on) in order forit to be counted as a valid entry.Note!To ensure the diagnostic functions are activated in the correct way alwaysfollow this working method:Ignition on.wait approximately 3 seconds.ignition off.ignition on againwait for 0.5 seconds. If a diagnostic trouble code(DTC) is stored, the indicator LED will flashonce. It is now possible to continue pressing thebutton to obtain system responses.activate the required diagnostic function within2.5 seconds.To activate diagnostics:the ignition must be onbattery voltage normal.-Stored diagnostic trouble codes (DTCs) can be erasedusing this function. The on-board diagnostic (OBD)system can identify 10 different faults in the form ofdiagnostic trouble codes (DTCs).To reading off diagnostic trouble codes (DTCs), proceed as follows:ignition ON, position I or II.wait approximately 3 seconds.ignition offignition on againwait for 0.5 seconds. If a diagnostic trouble code(DTC) is stored, the indicator LED will flash once.It is now possible to continue pressing the button toobtain system responses.press the REC button in twice within the following2.5 secondsread off the flashes from the REC indicator LED.The REC button indicator LED is on for 1 second andoff for 0.5 second. The timing between the numbers ina DTC code sequence is 2 seconds. The time betweentwo codes is 5 seconds. If no diagnostic trouble codes(DTCs) are set the code will be 1-1-1.For erasing diagnostic trouble codes (DTCs), proceed as follows:ignition ON, position I or II.wait approximately 3 seconds.ignition offignition on againwait for 0.5 seconds. If a diagnostic trouble code(DTC) is stored, the indicator LED will flash once.It is now possible to continue pressing the button toobtain system responses.press in the REC button four times within thefollowing 2.5 seconds-Note! The diagnostic trouble codes (DTCs) can alsobe erased by disconnecting the control module formore than 2 minutes (supply voltage powerdisconnected), because after 2 minutes the entirecontrol module memory will be erased!Diagnostic trouble code (DTC) 5–1–2 can only beerased by disconnecting the control module formore than 2 minutes or by carrying out a successfulself-adjustment.Hint: If the indicator LED still flashes once when theignition is turned on this means the erasure procedurehas not been successfully completed and the diagnostictrouble code (DTC) has again been stored.The exception is diagnostic trouble code (DTC) MCC 1–1–1 for certaincontrol modulesNote! On the MCC/STANDARD control modulesintroduced at production start-up of theS70/V70/C70 series must fault-tracing for MCC 3–4–2 be carried out if the REC button orangeindicator LED flashes once at ignition on(diagnostic trouble code (DTC) stored) but thecontrol module flashes out diagnostic trouble code(DTC) 1–1–1.This applies to control modules marked “S2”, “S3”or “S4”. See illustration.Self-adjustment of damper motorsThe climate unit damper motors can be self-adjustedwith this serviceThe damper motors are self-adjustingafter any of them has been removed or replaced orother work is carried out on the damper or linkage. Toensure correct self-adjustment the damper motors musthave voltage at generator supply level, e.g. the enginemust be idling.To activate self-adjustment, proceed as follows:start enginewait approximately 3 secondsstart engine without switching off the ignition before start engine without switching off the ignition before wait 0.5 seconds after releasing the key to positionII. If diagnostic trouble code (DTC) is stored theindicator LED will flash once. Only start pressingthe buttons after the flashingpress in the REC button three times within thefollowing 2.5 seconds.Note! The control module will automatically adjustthe damper motors when it is connected to the car's30 supply on condition that the control module hasbeen disconnected for more than 2 minutes. Engineidling during self-adjustment.OKAY! It worked Moderator, please pin this in helpful info section for folks with a '98 70 series with MCC Systems for Diagnosing and resetting codes on their climate control system without a code reader. Link to comment Share on other sites More sharing options...
Geevs Posted September 26, 2006 Report Share Posted September 26, 2006 I can't download the file, how do I do it? Or can you just send it to me. Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 27, 2006 Author Report Share Posted September 27, 2006 The only information you need (if you have a MCC) from the pdf file is in my thread right above yours...I figured a way out to put it into regular text and just put it in the body of this thread. The rest of the pdf deals with reading the codes (for ECC) with a Volvo Scan Tool, so it won't be useful to us here. Link to comment Share on other sites More sharing options...
