Slater Posted September 25, 2006 Report Share Posted September 25, 2006 I noticed that on my 01 V70 there is no ECU cooling hose. There is the nipple on the ECU top cover, but it's just open and there is no hose going into it. I was just going to shove a radiator hose 90 degree elbow and point it down so no water would get in, but I am not sure if a hose even goes on there or not. My 850 has one that goes from the radiator shroud to the ECU box but not sure on the P2 v70.Anyone know? Link to comment Share on other sites More sharing options...
loseR99 Posted September 25, 2006 Report Share Posted September 25, 2006 my dad's p2 s60 t5 is missing one as well. I just put a post up asking if anyone had the part number. Not sure if it affects performance or not, i'm sure a cool ecu is a happier ecu though. Whats the part number on the one on your 850? Link to comment Share on other sites More sharing options...
the underlørd Posted September 25, 2006 Report Share Posted September 25, 2006 and get this. the air flows THE OTHER WAY... from out the box, through that hose, and to the header panel. i couldn't believe it either. Link to comment Share on other sites More sharing options...
Slater Posted September 25, 2006 Author Report Share Posted September 25, 2006 and get this. the air flows THE OTHER WAY... from out the box, through that hose, and to the header panel. i couldn't believe it either.Is that only on the models that had an ECU fan? Link to comment Share on other sites More sharing options...
the underlørd Posted September 25, 2006 Report Share Posted September 25, 2006 Is that only on the models that had an ECU fan? IIRC, that's on 94+. Not sure on P2 cars. Link to comment Share on other sites More sharing options...
garbergtsi Posted September 25, 2006 Report Share Posted September 25, 2006 these are now all gonzo after the cooling fan recall. its normal. if you have one, you need the recall Link to comment Share on other sites More sharing options...
Serdar-S60T5 Posted September 26, 2006 Report Share Posted September 26, 2006 my 2001 S60 T5 doesn't have the ecu cooling hose either. and if you put your finger through the open end of the hose from the box there, you will find that it is blocked anyway. that hose was cancelled in our cars because they don't need it. Link to comment Share on other sites More sharing options...
