trance42 Posted September 27, 2006 Report Share Posted September 27, 2006 My transmission will not go in to gear when the car is running.My clutch pedal feels normal. I think either the Master Cyl is bad, the clutch fork slipped off of the throw out bearing or something to do with clutch/flywheel is broken.Thanks,Tim.. come on master cylinder.. easiest fix!! Link to comment Share on other sites More sharing options...
Seamus Posted September 27, 2006 Report Share Posted September 27, 2006 Better odds it is the slave on the trans..... Reading your post again, you say the pedal feels normal? It could be clutch problem??? A quick look at the slave and you can see if it is leaking.... Link to comment Share on other sites More sharing options...
trance42 Posted September 27, 2006 Author Report Share Posted September 27, 2006 well it goes in to gear fine when the engine is not running. i figured if it was in the tranny it wouldnt go in to gear then either. Link to comment Share on other sites More sharing options...
AJU Posted September 28, 2006 Report Share Posted September 28, 2006 well it goes in to gear fine when the engine is not running. i figured if it was in the tranny it wouldnt go in to gear then either.Look first to the hydraulics - as mentionend above, check your slave for leaks. Also check your master. I have replaced both for leaks. You can feel around inside the footwell for leaking from the master. There was brake fluid in the carpet when my master was seeping. If the hydraulics look ok, I'd bleed the system. If you have bled the system and the problem is still there, it's likely a problem in the clutch assembly. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted September 29, 2006 Report Share Posted September 29, 2006 If you press the pedal,while the engine is working,try to listen any strange noise from the gearbox,when you are trying to engage a gear.If you hear any unusual noise then your disc is broken. Link to comment Share on other sites More sharing options...
