psy Posted September 29, 2006 Report Share Posted September 29, 2006 Ok i'm racking my brain on this tired of looking at diagrams, and people with "unsure" answers, so let me ask some of you since some of you happen to live by installing systems, here is what I need to know.I have 2 12" DVC subs that are 4 ohm's currently I have them jumped so they are dropped down to 2 ohm's each one and go into a 2 channel amp, easy enough.My question is this because I'm rebuilding my system and changing out my amps, is there a way to wire up 2 12" DVC's that are 4 ohm's to a mono block amp as 2 ohm's, so that the amp will give me 2 ohm's instead of 4 for RMS wattage. If so could someone please explain with a diagram or word it out that this will work. thank you. Link to comment Share on other sites More sharing options...
wmartinlsmith Posted September 29, 2006 Report Share Posted September 29, 2006 yeah you will only be able to run one vc on each sub, it may be better to get svc, over the dvc, or get 1 ohm stable amp Link to comment Share on other sites More sharing options...
Owned Posted September 29, 2006 Report Share Posted September 29, 2006 2 ohm can't be done in mono for a pair of 4 ohm DVC. It would have to be stereo and wired in parallel. For mono, your only options are going to be 4 ohm in series and 1 ohm in parallel. Link to comment Share on other sites More sharing options...
psy Posted September 29, 2006 Author Report Share Posted September 29, 2006 yup figured as much, guess its off to a 2 channel that will give me what I want at 2 ohms' since I can at least get away with that, sometimes I wish I had these in 2 ohm from the start instead of 4 ohm oh well. thanks guys. Link to comment Share on other sites More sharing options...
paulr Posted September 30, 2006 Report Share Posted September 30, 2006 Get an amp that's 1-ohm stable and run them in 1 ohm. Use Google - many amps can run at one ohm and aren't labeled as such. Allows you to get a lot of power into the subs from the same relative "size" amp. Many competition amps see less than one ohm. Oldschool soundstream amps had a reputation for going real low (like 1/4 ohm) but I'm sure there are many out there that will do what you want. Link to comment Share on other sites More sharing options...
