Guest Guest_Brian_* Posted September 30, 2006 Report Share Posted September 30, 2006 Hi everyone I own a 2000 Volvo S-70. Recently everytime I come to a complete stop the cars rev drops from 1000 rpm to about 500-750rpm. As it does this the engine will shake as if it wants to stall but it never does (my foot is still on the brake pedal). Then it will go back up to 1000 rpm. I know this is not normal behavior and I'm very worried about my car because I don't like my cars to run like crap or suffer. Anyways I went to Advance Auto and did the OBD scan and it threw a code P0171 System Too Lean (Bank 1). I was told that this may be an oxygen sensor but they weren't sure. I also get a message that says "disc" on my trip computer. Does anyone know what that is? So here I am wondering and that is why I am here. What is wrong with my car? Its my baby and I really hate to see it this way. Please if anyone has had any experience with this symptom while stopping please share your experience and what you did to fix it. Any help is greatly appreciated. Thanks much. Link to comment Share on other sites More sharing options...
BtownVolvo Posted September 30, 2006 Report Share Posted September 30, 2006 Hi everyone I own a 2000 Volvo S-70. Recently everytime I come to a complete stop the cars rev drops from 1000 rpm to about 500-750rpm. As it does this the engine will shake as if it wants to stall but it never does (my foot is still on the brake pedal). Then it will go back up to 1000 rpm. I know this is not normal behavior and I'm very worried about my car because I don't like my cars to run like crap or suffer. Anyways I went to Advance Auto and did the OBD scan and it threw a code P0171 System Too Lean (Bank 1). I was told that this may be an oxygen sensor but they weren't sure. I also get a message that says "disc" on my trip computer. Does anyone know what that is? So here I am wondering and that is why I am here. What is wrong with my car? Its my baby and I really hate to see it this way. Please if anyone has had any experience with this symptom while stopping please share your experience and what you did to fix it. Any help is greatly appreciated. Thanks much.Hey man.I'm thinking this is because of your ETM (Electronic Throttle Maint.) If you take it to Volvo, they will give you a free software update, and if that doesn't fix it then they might install a brand new one in for free. Read up here. Link to comment Share on other sites More sharing options...
MadeInJapan Posted September 30, 2006 Report Share Posted September 30, 2006 As you come to a stop and take your foot off the gas and onto the brake pedal, your car will pull vacuum. If vacuum lines are clogged up really badly, the rpm's will dip considerably. It may be time for you to check and service your pcv hoses. I just found a write-up on how to do this ...a few posts down in this section so check it out. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 30, 2006 Report Share Posted September 30, 2006 Hey man.I'm thinking this is because of your ETM (Electronic Throttle Maint.) If you take it to Volvo, they will give you a free software update, and if that doesn't fix it then they might install a brand new one in for free. Read up here.Hi BtownVolvo, I have the upgraded software for the ETM. When I made an appointment with Bobby Rahal Volvo for my transmission flush I asked if the software was updated for my vehicle and they said yes. I also had a Throttle Body cleaning done as well a few months back too. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 30, 2006 Report Share Posted September 30, 2006 As you come to a stop and take your foot off the gas and onto the brake pedal, your car will pull vacuum. If vacuum lines are clogged up really badly, the rpm's will dip considerably. It may be time for you to check and service your pcv hoses. I just found a write-up on how to do this ...a few posts down in this section so check it out.Hi MadeInJapan,My Dad thinks thats what it is too. He believes its the hose that leads to the brake booster and that the vacuum is bad. It could be alot of things but hopefully it is a vacuum and not a sensor or worse the the throttle body. Thanks so much for your help. Link to comment Share on other sites More sharing options...
BtownVolvo Posted October 1, 2006 Report Share Posted October 1, 2006 You might get a boost/vac gauge to make sure everything checks out. I never really thought about it but yeah that sounds more likely. Link to comment Share on other sites More sharing options...
