Über855R Posted October 3, 2006 Report Share Posted October 3, 2006 What do you guys have your spark plugs gapped at? What is the difference in performance/temp/timing with having a larger versus smaller gap? I would like to get some educated opinions if thats possible. Link to comment Share on other sites More sharing options...
prasamin Posted October 3, 2006 Report Share Posted October 3, 2006 gap down for better spark...not too far or you'll get blowout and other stupid issues.i've got my Champion RC7YC plugs down to .023....running 18psi no problems. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 3, 2006 Report Share Posted October 3, 2006 Theoretically to create the most power, you want to gap as large as possible before you experience any problems, such as blowout and misfiring. However, on these cars ive found a .025 or even .023 gap to work great for higher boost, right now on 21lbs of boost im running .025 gap, on my 75 shot of nitrous and 16 pounds i ran a .23 gap with the plugs that Prasamin mentioned, and even on boost it worked great. Link to comment Share on other sites More sharing options...
Volvoson Posted October 3, 2006 Report Share Posted October 3, 2006 OEM @ 0.025, no problems at 18-19psi. Link to comment Share on other sites More sharing options...
POOKDIZZLE Posted October 3, 2006 Report Share Posted October 3, 2006 Cold copper (due to nitrous) gapped at .025 at 20psi, runs great ;) Link to comment Share on other sites More sharing options...
turbor850 Posted October 3, 2006 Report Share Posted October 3, 2006 Ben is right, for most power you want to gap the plugs higher before getting spark blowout.With an upgraded ignition (coil, MSD 6A) you can run a tad bigger gap.25/.26 is what i go for, every so often when i check I get 1 or 2 at .27 or .29 and still experience no blowoutoh and at 22 psi/24psi/26psi :P Link to comment Share on other sites More sharing options...
Gioseppe Posted October 3, 2006 Report Share Posted October 3, 2006 bosch fr7dc's at .025, msd6a, bosch wires, stock coil. 17 psi no blowout with spikes of 18-19. Link to comment Share on other sites More sharing options...
Über855R Posted October 3, 2006 Author Report Share Posted October 3, 2006 Ben is right, for most power you want to gap the plugs higher before getting spark blowout.With an upgraded ignition (coil, MSD 6A) you can run a tad bigger gap.25/.26 is what i go for, every so often when i check I get 1 or 2 at .27 or .29 and still experience no blowoutoh and at 22 psi/24psi/26psi What is spark blowout? What does it feel like or sound like? Would you experience it in the higher RPM range or lower range? How do you know if your gap is too big or just right? Link to comment Share on other sites More sharing options...
Volvoson Posted October 3, 2006 Report Share Posted October 3, 2006 What is spark blowout? What does it feel like or sound like? Would you experience it in the higher RPM range or lower range? How do you know if your gap is too big or just right?It is basically when the car hickups just a little under load, it's the car misfiring (not burning all of the gas in the combustion chamber?)... Link to comment Share on other sites More sharing options...
Johann Posted October 3, 2006 Report Share Posted October 3, 2006 OEM @ 0.025, no problems at 18-19psi.0.031, 19.5 PSI @7K rpm, no problems. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 3, 2006 Report Share Posted October 3, 2006 If you have an open exhaust it will sound like a rapid fire machine gun.What is spark blowout? What does it feel like or sound like? Would you experience it in the higher RPM range or lower range? How do you know if your gap is too big or just right? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 3, 2006 Report Share Posted October 3, 2006 .028 @ 15 PSI If you have an open exhaust it will sound like a rapid fire machine gun. That is soooo true!! Link to comment Share on other sites More sharing options...
fromtheshadows Posted October 4, 2006 Report Share Posted October 4, 2006 What kind of plugs are you using Johann? Link to comment Share on other sites More sharing options...
Volvoson Posted October 4, 2006 Report Share Posted October 4, 2006 What kind of plugs are you using Johann?Since he quoted my post and responded with his boost levels, my guess is OEM's at 0.031 :) Link to comment Share on other sites More sharing options...
gdizzle Posted October 4, 2006 Report Share Posted October 4, 2006 OEM, 0.025 16lbs no minor missfires still, but pretty sure it's not plug related. Link to comment Share on other sites More sharing options...
