MadeInJapan Posted October 3, 2006 Report Share Posted October 3, 2006 My wiring right before the bulb plug on the driver's side (LHS) on my S70 has a short in it. When I go over bumps the fog light on that side goes out and sometimes comes back on. I've looked at it, taped it, etc...short of cutting the wire and re-taping it. Seems that this wire goes all the way up to behind the headlights and plugs into the wiring that goes to the headlights. If so, I need the wire from there all the way down to where the fog light is with both plugs attached. If this isn't so and someone knows how the foglight wiring is set up, please post. I've searched both in my copy of the Volvo software and on here and find no information. Thanks in advance! Link to comment Share on other sites More sharing options...
MadeInJapan Posted October 7, 2006 Author Report Share Posted October 7, 2006 Found out the "plugs" are called pigtails. Does anyone have this wiring? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2006 Report Share Posted October 7, 2006 Found out the "plugs" are called pigtails. Does anyone have this wiring?Isn't it just a 2 pin connector? I think they use the same ones on fuel injectors and all sorts of other stuff. It shouldn't be too hard to find. Link to comment Share on other sites More sharing options...
the underlørd Posted October 7, 2006 Report Share Posted October 7, 2006 hard wire them to the headlights! wheeeeee! Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2006 Report Share Posted October 7, 2006 hard wire them to the headlights! wheeeeee!Maybe you should take your own advice!! Link to comment Share on other sites More sharing options...
the underlørd Posted October 7, 2006 Report Share Posted October 7, 2006 Maybe you should take your own advice!! after playing the mix and match game with relays... trust me, i'm about to. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2006 Report Share Posted October 7, 2006 after playing the mix and match game with relays... trust me, i'm about to.We'll work on it tomorrow in the BCC garage at 930 in the morning. Me thinks we shuold bring beers. Link to comment Share on other sites More sharing options...
the underlørd Posted October 7, 2006 Report Share Posted October 7, 2006 We'll work on it tomorrow in the BCC garage at 930 in the morning. Me thinks we shuold bring beers. uhmmm, yea.. you just give me a call when you get back to the bestside m'kay. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2006 Report Share Posted October 7, 2006 uhmmm, yea.. you just give me a call when you get back to the bestside m'kay.i'll buy the beers.......you know there is nothing better than drinking PBR at 10 in the morning!! Link to comment Share on other sites More sharing options...
the underlørd Posted October 7, 2006 Report Share Posted October 7, 2006 i'll buy the beers.......you know there is nothing better than drinking PBR at 10 in the morning!! you know it. and back to Dave's topic.. HOOK DIS FOO UP ! Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 7, 2006 Report Share Posted October 7, 2006 you know it. and back to Dave's topic.. HOOK DIS FOO UP !Oh right....wire them to the headlights using a connector you took from your fuel injectors. Link to comment Share on other sites More sharing options...
MadeInJapan Posted October 8, 2006 Author Report Share Posted October 8, 2006 Hey now...I don't want them on all the time. I even did the cute little relay surgery for them so I want to be able to turn them off as well as run them without the headlights. Still....anyone have the piggy tail wire? Please, purddy please? ? :blink: Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 8, 2006 Report Share Posted October 8, 2006 Hey now...I don't want them on all the time. I even did the cute little relay surgery for them so I want to be able to turn them off as well as run them without the headlights. Still....anyone have the piggy tail wire? Please, purddy please? ? Did you check to see if it is the standard 2 pin? Link to comment Share on other sites More sharing options...
MadeInJapan Posted October 8, 2006 Author Report Share Posted October 8, 2006 Did you check to see if it is the standard 2 pin?Just now checked...yeah, it is...it has a metal clip across the connecto that you push in to pull it off of the bulb housing. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted October 9, 2006 Report Share Posted October 9, 2006 Just now checked...yeah, it is...it has a metal clip across the connecto that you push in to pull it off of the bulb housing.There are about 20 other things on your car that use that connector, I'm sure you can find a new one. If you don't let me know i can get one. Link to comment Share on other sites More sharing options...
