Phil94850 Posted October 3, 2006 Report Share Posted October 3, 2006 for those of you that have installed the side turn lights ( where the volvo emblem is located ) its my understanding that the volvo emblem just pops out ? how do you gain access behnd the emblem to wire up the light ? do u have to remove the inner fender well to get to it ? ive got my lights coming tomorrow and would like to know the easiest way to hook up. Thank you for any help !!! Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted October 3, 2006 Report Share Posted October 3, 2006 for those of you that have installed the side turn lights ( where the volvo emblem is located ) its my understanding that the volvo emblem just pops out ? how do you gain access behnd the emblem to wire up the light ? do u have to remove the inner fender well to get to it ? ive got my lights coming tomorrow and would like to know the easiest way to hook up. Thank you for any help !!!I used a coat hanger to fish the wireing harness up to the turn signals where I tapped there. Easy. Link to comment Share on other sites More sharing options...
fastboy Posted October 3, 2006 Report Share Posted October 3, 2006 I used a coat hanger to fish the wireing harness up to the turn signals where I tapped there. Easy.yep, that is about the easiest way to do it. Link to comment Share on other sites More sharing options...
Guest S7013g Posted October 3, 2006 Report Share Posted October 3, 2006 I used a coat hanger to fish the wireing harness up to the turn signals where I tapped there. Easy.Agreed Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted October 3, 2006 Report Share Posted October 3, 2006 +1. I used audio wire for mine. worked like a charm Link to comment Share on other sites More sharing options...
Phil94850 Posted October 3, 2006 Author Report Share Posted October 3, 2006 thank you for the advice everyone... paintballplayer.... i noticed on your mod list you blacked out i guess your bumpers and such with kiwi show polish ? did it work pretty good and does it hold up. i need to do it on my car ... Link to comment Share on other sites More sharing options...
prasamin Posted October 3, 2006 Report Share Posted October 3, 2006 you have to floss the emblems off, not "pop" them offyou may be lucky and have harnesses attached to the back of them, only way to find out is get the emblems off.if not, then tap your front turn signals, fish wire through the fender to the hole, and have a harness ready Link to comment Share on other sites More sharing options...
boostwagboy Posted October 3, 2006 Report Share Posted October 3, 2006 thank you for the advice everyone... paintballplayer.... i noticed on your mod list you blacked out i guess your bumpers and such with kiwi show polish ? did it work pretty good and does it hold up. i need to do it on my car ...go to IPD and go to all the claeing and detail crap. buy FOREVER BLACK. sooo worth it. works the best. and lasts longer than shoe dye.permenatly dyes ur bumper black. and its easy as hell to put on. Link to comment Share on other sites More sharing options...
Phil94850 Posted October 4, 2006 Author Report Share Posted October 4, 2006 forever black.. ok.. pras... you say you have to floss ?? them off.. you mean you have to get in behind them and work em off ?? Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted October 4, 2006 Report Share Posted October 4, 2006 go to IPD and go to all the claeing and detail crap. buy FOREVER BLACK. sooo worth it. works the best. and lasts longer than shoe dye.permenatly dyes ur bumper black. and its easy as hell to put on.tried that stuff, sucked compared to the dye, trust me the dye is better, at least if you want black trim, my trim is perfect. Link to comment Share on other sites More sharing options...
prasamin Posted October 4, 2006 Report Share Posted October 4, 2006 forever black.. ok.. pras... you say you have to floss ?? them off.. you mean you have to get in behind them and work em off ??they are stuck on there with some frikin double sided tape from hell.i applied a little heat to the emblem, and got some Glide that I just happened to have laying around , and got under the tape and started gently sawwing away at the damn things. Link to comment Share on other sites More sharing options...
bmcintyre Posted October 4, 2006 Report Share Posted October 4, 2006 they are stuck on there with some frikin double sided tape from hell.i applied a little heat to the emblem, and got some Glide that I just happened to have laying around , and got under the tape and started gently sawwing away at the Darn things.By Glide Pras means dental Floss... not Astro-glide. Stop confusing the noobs Pras!B Link to comment Share on other sites More sharing options...
prasamin Posted October 4, 2006 Report Share Posted October 4, 2006 By Glide Pras means dental Floss... not Astro-glide. Stop confusing the noobs Pras!Bi guess you could use the Astro Glide too, but you wouldn't get anywhere except into the back door *pun intended* Link to comment Share on other sites More sharing options...
Phil94850 Posted October 4, 2006 Author Report Share Posted October 4, 2006 lol.. thanks for the help pras.. ill give it a try. Link to comment Share on other sites More sharing options...
WhiteT5 Posted October 4, 2006 Report Share Posted October 4, 2006 Hairdryer + fishing line worked for me. Some of the cars are already pre-wired (there's a socket inside the fender) for sidemarkers. I found out mine was this way, so it was uber-easy. Link to comment Share on other sites More sharing options...
