Anthrpicdecadnce Posted October 4, 2006 Report Share Posted October 4, 2006 i found that my slave cylinder has sprung a leak, so i have to replace the part. i have gotten as far as removing the circlip and the fluid line, so all we have to do is remove it, however...it's in there good. i'm just asking some advice on some methods of actually removing this stuborn part so i can actually go ahead and install the new one. the help would be greatly appreciated because this part just won't come out all the way. Link to comment Share on other sites More sharing options...
AJU Posted October 4, 2006 Report Share Posted October 4, 2006 Huh, funny. Removing the circlip was the most difficult part for me. How about reconnecting the fluid line and stepping on the pedal? Might be a bit of a PITA to get the system bled just to disconnect, but the pressure most certainly should break it loose. Link to comment Share on other sites More sharing options...
Seamus Posted October 4, 2006 Report Share Posted October 4, 2006 I recall one has to unbolt the brake booster from the firewall (four 13mm head nuts) to be able to move it forward to clear the path for the clutch cyl.? Link to comment Share on other sites More sharing options...
Anthrpicdecadnce Posted October 5, 2006 Author Report Share Posted October 5, 2006 Huh, funny. Removing the circlip was the most difficult part for me. How about reconnecting the fluid line and stepping on the pedal? Might be a bit of a PITA to get the system bled just to disconnect, but the pressure most certainly should break it loose.couldn't add any pressure. there was a horrible leak. it's not like it would do anything anyway. well. it doesn't matter now. i already removed the part. it really wasnt that bad. i removed the radiator fan and used a rubber mallet to knock the thing out of place while a friend shook on it.thanks though. Link to comment Share on other sites More sharing options...
